Ultrasonic Cleaners |
mdtractormechanic ![]() Orange Level ![]() Joined: 26 May 2011 Location: MD Points: 662 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Jul 2012 at 10:14pm |
Has anyone here used these ultrasonic cleaners to clean tractor parts? Would it be safe to clean magneto parts excluding coil and condenser? I understand some clean carbs in these cleaners.
Joe's 1939 Model WC, 1940 Model RC, 1944 & 1950 Model C's, B-125 PU
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24697 |
As long as the chemicals you use aren't harmful, I don't see why not.
I built a 'poor boys U/S cleaner'...actually it's a big coffee can with a coil of copper tubing in the bottom with a few 1/16" holes in it that a cheap aquarium air pump blows into.The air agitates the 'gunk' cleaner,moving the 'stuff' around. Left overnight it does a decent job of getting most of the crud off. I'm not in a hurry so 1-2 days is fine for me as I have lots of 'projects' on the go.
hth
jay
Butch(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
WIth mineral solvents and disposal going out of sight I considered ultrasonic, it works very well but is expensive,, no make that DARNED expensive when it gets big enough to be useful beyond small parts. I went the hot water/detergent spray cabinet route and it works very well for my situation. If busy around the shop I keep the heat on for instant use. When not busy I turn it on when I start tearing something apart and dont have to often wait for it to be ready to use. I am not the safety or enviro freak type but I have to say it does not bother me one bit to not be breathing solvents and have them soaking through my skin. Disposal is as easy as sending the fluids down the sewer and the solids go into cans for donation to the semi yearly household hazardous disposal truck. My unit came from Smith Equipment in Indianapolis. |
Butch, when you say expensive, do you mean the initial cost of the U/C and water based solvents or what? I'm interested in a 2 1/2 gal size to do parts I would normally do at the solvent table. Everything else gets pressure washed. Thanks
Initial cost, I didnt have to get any deeper into it. Unit big enough for blocks, auotmotive transmission cases etc was $20K. I think it was around 100 gallon. Parts washer big enough to do same work was less than 4K. Ultra sonic would no doubt be better for deep cleaning things like carbs but that constitutes a very small portion of my work. Kind of depends how much of what kind of work a person does, budget and room in the shop.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6069 |
Professional/business concerns and EPA compliance are tough- cost of compliance is one of the reasons so many small businesses close doors.
Fortunately, they can't walk into my shop... I'm not a business... So here's how I do it: I've got a 55-gallon drum, laid on it's side... I plasma-zortched off the top 1/3 of it, put hinges in the back, and welded a nice rim around top and bottom. Flips up like a bbq grill. I got a long straight coil-spring holding the cover up- one end to a bolt in the top, other to bolt in the bottom. When up, the spring is straight, and will hold the cover. Bump the center of that spring, and the cover shuts pronto. Seals tight enough to snuff out a fire. Whole thing is on angle-iron legs, with wheels and a nice big shelf on the bottom. Bung-hole facing down, with barrel tilted slightly it's way, and a piece of steel screen, underneath is some cast-iron fittings and a ball-valve, leading to a 5-gallon steel fuel can full of mineral spirits. Small hole punched in the top of the fuel can, threaded in a tapered pipe adapter with compression fitting, slid a piece of copper tubing down to about 2" off the bottom of the can. On the top of that tube is a barb fitting, going to an electric fuel pump on the side of the barrel. There's a switch on the side, that shuts off the pump if the cover is down. Another switch on front allows me to turn the pump on, but only if the door is open. I use a battery charger as the power supply... it's mounted about 10' away, and easily disconnected if there's a problem. Pump outlet goes through copper INTO the barrel, where it's connected to a hose with brush on the end. I can put a WC block in this thing, and clean it just fine... and I'm pretty sure I can close the cover with it in there. Everything else is pretty easy. I have a piece of gridwork made from 1/2" angle iron that I can set inside to elevate the workpiece just below the halfway point of the barrel. If I decide that I need a big vat of mineral spirits, I close the valve on the drain and let'r fill. The barrel holds well more than the can, so it can't overflow. Building is concrete and steel, with no combustables anywhere near. All lighting is overhead, on track, and LED, so plenty of illumination and no high-temperature surfaces nearby. Nice thing, is that I've been using the same 5 gallons of mineral spirits for at least 12 years... the sludge down at the bottom has required me to lift the pickup tube to about halfway point now, but still doing just fine. Eventually, it will get so high that I'll need to deal with the sludge and recharge it with more solvent, so what I'll do, is pump out as much of the liquid that I can, and then pour the sludge onto a steel tray covered with softwood, and light it up... and it will burn down to the point where the only thing left in the sludge is a half-coffee can of dirt. Then I stick a magnet in it, and extract all the iron dust, and send the rest to the landfill in a sealed plastic jar. Then pour in another 3 gallons (12 year supply) of mineral spirits. As much as people tout the biodegradeable cleaners (and I love my Orange Goop and other citrus-based stuff), the problem is, the materials they REMOVE, are not biodegradable. IF the materials removed are not contained, they wind up contaminating the environment. If they are, they must be taken for hazmat disposal INCLUDING the biodegradable solvents and water that extracted them... there's MORE left than what was started WITH. Now realize- I'm wholly against people dumping oil products into streams, draining coolant onto the ground, and basically assuming that whatever they rinse off, will just 'go away'. It doesn't. I'm sure there's many who'll object to my old-school parts washing setup, but in 12 years, I've never had to purchase additional solvents, never had to recapture quantities of water-soluable biosolvents mixed with crud-goo, and never put anything into the floor, or ground, or water supply anywhere. Everything flammable was burned, and while that may constitute a release of something somewhat bad, it's no worse than two seconds or so of someone's car catching fire. |
With all that garbage being said... I snagged a little ultrasonic cleaner, type that jewelry shops use to clean rings, watch bands, and stuff. Not very big, but if you put a handful of carbeurator parts in one, and pour in a smidgen of light solvent, they knock it right off quick. I wish it were bigger... so I could put a magneto or distributor body in there, or a voltage regulator... and a quart of white vinegar, it'd be the cat's meow.
orangeman ![]() Orange Level ![]() Joined: 12 Sep 2009 Points: 1855 |
Dave: I like the description of your cleaning set - up and approach to disposal. You have a very good system that is reasonably sustainable given our hobby. Appreciate you not dumping as we only have one environment and the resources we depend upon like fresh clean water and clean air are only as good as our actions to keep them that way.
I have learned much from your post, so I thank you for that! Orangeman
Another idea....I see 'mist makers' for aquatic pools advertised..they make a low lying mist,great effect. I think they are high powered U/S heads for about $60.Might be worth a trial run in a large tank to see what happens??
If it doesn't look like it'll work, just return saying the 'boss' said 'take it back'.....
Thanks for the replies but they didn't really answer the initial question.
