Model C Starter Linkage
DrDirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrDirt Quote  Post ReplyReply Direct Link To This Post Topic: Model C Starter Linkage
    Posted: 26 Jun 2012 at 7:51pm
The two photos show the fixtures for the starter linkage on my 1942 Model C.  The rod goes thru a washer welded to a bolt.  I'm curious about what the original fixture was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 7:58pm
mine had a littel U strap under the battery box bottom.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 8:05pm
You also need the correct rod. that is a pull rod and should go to a loop up under the throttle quadrant. the push rod just goes through a L bracket with a hole in it. In the morning I can get pictures of both types. It's to dark in my shed to get any tonight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 8:07pm
Most likely a piece of metal angle with one side bolted to the battery box mount and the starter rod running through the other side with a return spring, cotter pin and washer installed on the rod if it is the push style. The pull style usually had a u clamp mounted on the steering support post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 8:09pm
Dave must type faster than I do.
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 8:09pm
The loop should be 90 degrees to the rod and a spring between the washer and rod clip. I think there is 2 different setups depending on year. You will find numerous variation fabed up over the years.
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 8:52pm
What size is the "farmerized" cotter pin?  Looks to be about an 8D.  I've used a few of the same kind in various sizes.   Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrDirt Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2012 at 8:14am
Posted: Yesterday at 9:05pm By Dakota Dave
Thanks, That would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrDirt Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2012 at 8:24am
Posted: Yesterday at 9:07pm By Hubert (Ga)engine7
This is indeed a pull rod.
