allis 7060 running hot |
AC 426 power
Topic: allis 7060 running hotPosted: 14 Jun 2012 at 6:38pm |
Allis Chalmers 426 7060 is running hot i have flushed the radiator out and it still runs hot fan belts are good and all..i have been running a jd 535 baler.any thoughts? Ask for more info if needed
Russ SCPA
Joined: 12 Sep 2009 Location: Southern Pa Points: 256 |
Posted: 14 Jun 2012 at 6:52pm |
Make sure the foam on the sides of the radiator are in place and in good condition, and be sure to blow the radiator, hydraulic, transmission coolers, and AC condensers out backwards with high pressure air every 200-300 bales.
AC 426 power
Posted: 14 Jun 2012 at 7:01pm |
Ok thanks how many coolers are supposed to be infort of the radiator?
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2592 |
Posted: 14 Jun 2012 at 7:44pm |
Thermostat? New radiator cap?
AC 426 power
Posted: 14 Jun 2012 at 7:53pm |
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 14 Jun 2012 at 7:59pm |
Best I can remember there is either 2 or 3 depending on the transmission
1, hydro oil cooler 2, A/C condenser 3, Power Shift Trans cooler if applicable
Still in use:
Orange Blood
Posted: 14 Jun 2012 at 8:01pm |
I forgot to ask, do you have the pump turned up, and what is "hot" in temp numbers?
Have you used an infared thermometer or some other device to verify the temp shown on the gauge?
Still in use:
AC 426 power
Posted: 14 Jun 2012 at 8:44pm |
Russ SCPA
My powershift has 3 coolers and it does get loaded up with hay chaff to point it will warm up.
Orange Blood
Posted: 14 Jun 2012 at 9:23pm |
Well I don't think you have hurt anything yet, so long as you take the load off, and let it cool, when it gets that hot. I think you need to find the fault in the wiring, sounds like you have a wire loose between the gauge and the sending unit, or possible rubbing a bare spot in somewhere.All of the suggestions are good ones, double check your foam seal, and don't only blow out, but when the engine is cool, wash out the rad and cooler with a garden hose, and a pressure gun, not a pressure washer, that way you won't bend the fins. The coolers will get plugged as well, they also need blown and washed out. After that, run the beast up to temp, feel the radiator in front to see if the temp at the top and bottom, are drastically different, slightly defferent, mostly cold, or mostly hot. Once you get that done, you may want to consider flushing the system, and putting in a new thermostat, one that you check in a pan of water on the stove before installing.
Still in use:
AC 426 power
Posted: 14 Jun 2012 at 9:29pm |
Thanks for all the help its greatly appreciated
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2316 |
Posted: 14 Jun 2012 at 9:35pm |
There are two thermostats in this I beleave, might be one stuck, 7030 did this, worked ok on light load but as soon as harder pull got hot right away.
MACK
Posted: 14 Jun 2012 at 10:04pm |
Have the rad. rodded out on the inside. Flushing out don't do much for a pluged rad. When the tubes get coated with crud keeps the heat from getting out to fins to tranfer heat. MACK
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 15 Jun 2012 at 3:45am |
my 7010 heated up the other day too...blew the juice out of the cap...went and got a new thermostat for it, thought i'd try that...haven't taken it apart yet, but the one they gave me is a little dinky thing! it's smaller than what i have ina pickup or car! guess i'll find out when it take it apart. it's the orgiginal thermostat!
Posted: 15 Jun 2012 at 5:38am |
Takes TWO thermostats.
