hydraulic cylinder
orangeonly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeonly Quote  Post ReplyReply Direct Link To This Post Topic: hydraulic cylinder
    Posted: 09 Jun 2012 at 10:04pm
anyone know what i could use to temporarily fix a cylinder.  you can take odd the end and see the o ring has a bad spot.  was wanting to haul some hay in tomorrow
If it ain't orange it ain't worth ownin'
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 10:19pm
A new O-ringErmm
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeonly Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 10:23pm
I knew someone would say that. I won't be able to get one til mondayLOL
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 11:08pm
Get some natural rope that will wick the oil and expand when wet. Separate the weave till a desired thickness dry will match the O-ring groove. Twist it up tight and mash into the groove with a little thickness cut off each end and overlap the ends. When you install it spray it with light oil of your choice. When you bleed it out it should expand and seal enough to get you by awhile.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 8:11am
try NAPA which might be open today as they have assortments of O rings you can buy individually .
Lars(wisc) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wisc) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 9:41am
why not switch cylinders? We switched them all the time. We never left a hyd. cylinder on  an implement that was not in it's season of use.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 10:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeonly Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 3:03pm
thanks dave the rope worked well.    no leaks.....it was gushing last night.....got all the hay hauled
