CA Axle Smoking
JarrodACFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Topic: CA Axle Smoking
    Posted: 07 Jun 2012 at 11:16am
I was raking hay today and when I got home(about 1 mile on the road) and parked it, white smoke was coming out of the RH brake opening and the hand clutch opening. I let it sit for a minute and then felt the axle housing. The housings on both sides of the transmission along with the transmission was hot. The smoke stopped after about 2 minutes after I noticed it. What do you guys think is wrong?
Any help will be appreciated,
JarrodACFan
P.S. I added some trans. fluid after I saw it smoking, in case that matters.
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 11:22am
Dragging brake.
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 11:22am
Just a guess, the brake may be rusted in place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 11:23am
The mice aren't going to like you for disturbing their nests.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 12:22pm
That is possible, but when we painted it a month or two ago, we took the pressure washer and stuck it down in that hole and REALLY washed it good. Also, it has been blown out with air many times.
We just replaced the brake shoes when we restored the tractor, so I don't thik that is it.
I am leaning toward the brakes dragging, I will check it when I get a chance today and tell you guys what I find out.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 12:28pm
Did it smell similar to someone welding? That seems to be the smell I get when I forget to unlatch the brakes on Dad's 656 Farmall. Shocked
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 12:34pm
When I install new brakes on old tractors I leave them set with more free travel for a day or two and that will let them wear in some without all the white smoke coming out the mice holes. lol
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 12:35pm
Inner bearing going out? You would think it would make noise though.
Galatians 5:22-24
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 12:48pm
Are you missing any tools?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 5:58pm
Nope, we made sure not to drop anything in there!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 5:59pm
When dad got home, he looked at it and he thinks the brakes were just seating and I noticed that one brake pedal came down more than the other, so I loosened the one up so they are equal now. We will see what happens tommorow because I have some more raking to do.
