pulling this weekend
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: pulling this weekend
    Posted: 03 Jun 2012 at 11:47am
my 57 WD45. wondering if I might rty moving the wheels out a little? would this do any good?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 12:04pm
I personally think its better to run the wheels in narrowing the rear end as much as possible . This is the reason I never ran fenders to couldnt fasten them for the tire .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 2:55pm
I always try to set the wheels out a little, if u look at others they are always about the same ;; moving out gets u in a different track
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 8:29pm
I pulled my IHC "C" once, my uncle said that with the wheels all the way out, the spring of the axels would help you pull more, so I put my wheels all the way out, we were pulling on concrete, dead weight. A friend brought his IHC "C" with it's wheels all the way in. I asked him why, he said he figured that way the wheels would be inside the burned rubber on the track that others had left on the concrete. I beat him and got second place. A Supper C beat me.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 8:26am
with any luck we will be pulling in damp clay
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 9:16am
is the track level all the way across or crowned.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 9:27am
Depends on whether or not they bring in more dirt
German Shepherd dad
#WD234847
#WD88193
Rod B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 2:11pm
narrow is going to be better.  Most places will require fenders, but I suppose if you can't go verry fast than one could run without them.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 3:50pm
Most Farmall or JD's don't have fenders around here.
I set mine in as close as I can. The antique pull guide has some info on the science of it.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 4:03pm
theyre required if they were standard equipment. Back in the early Farmall and John Deere days fenders were an option.
German Shepherd dad
#WD234847
#WD88193
This page was generated in 0.032 seconds.
