AC 6060 Wheels
AC Nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Nut Quote  Post ReplyReply Direct Link To This Post Topic: AC 6060 Wheels
    Posted: 30 May 2012 at 1:10pm
Just bought a 6060 with cab and has MFWD. Rear tires are down to 30% and are on 28 inch rims. They look very undersized for the tractor. Does anyone know if I could put 34 inch rims on and if so, where I might locate? I am in MN.
Thanks.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 1:43pm
If you change the back you must change the front.  Check owners manual for correct sizes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Nut Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 1:56pm
I just realized that. Do they make a higher profile tire in the 28" size? Not sure if that would mess with the front/rear ratio. I don't want to buy a new tranny.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 2:03pm
Mine came with 18.4 x 28.  Ordered it that way because that is what the 180 it replaced had. It was a very bad choice.  I have put radial 16.9 x 34 on it and they made a much better puller out of it.  Still far too light to do any real pulling of implements but know it does not get stuck on wet grass with the baler and two loaded wagons on behind.  I considered 15.5 x 38 but found they had almost exactly the same rolling circumference as the 16.9 x 34 and I was able to find the 34" rims when doing so.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 2:30pm
Did you get the one on tractor house? If so it looks sweet. Let us know how it works out for you . Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Nut Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 3:10pm
Amos-
Did you change the front tire size to accomodate the larger rears? I am afraid it may be hard on the tranny to mess with the ratio. Someone told me that I would have to switch to 28" on the front if I go with bigger tires in back.
Rutlege_
This is the one on Tractorhouse. Made an offer of $12K; he countered with $12 1/2 and I went with it. The interior didn't have a scratch in it, the body is completely straight, no leaks and ran like a top. Talked to the previous owner who said he just used it to pull a manure spreader and needed something bigger. He went with a 110 HP Kubota.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 3:20pm
If it had been closer to my part of earth i would of had a angry wife. My son and I looked at it last weekend on tractorhouse. I am glad you got it.and if it don't work out for you and you want to take a vacation in east Tennessee just put it on a trailer and bring it with you. haha Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Nut Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 3:24pm
Should work out nicely. I will keep your post just in case.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 7:49pm
Mine is 2 wd.  I have never seen a fwa 6060 with the small rear tires on it.  Most that I saw had 15.5 x 38 and a few with 18.4 x 38.
