7000 shift lever needed
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Topic: 7000 shift lever needed
    Posted: 28 May 2012 at 12:34pm
So I got the top cover on and found that the shift lever under the cover is broken.  It is a clean brake a little bit away from the rounded part.  I'll try to post pictures later.  Does anyone have part number 70262260 (number 34 in the picture).  I believe it is specific to a black belly 7000 shifter assembly.  Otherwise, do you think it would be a reliabile fix to grind a groove around the break and weld it back with a 6011 pass followed by a 7018 pass?  The break is above the machined portion.
Thanks
Hurst
1979 Allis Chalmers 7000
5800 Hours
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 8:46pm
I have welded other shift levers back together after they were broken and when we were moving their location or changing the location of the transmission.  I always used just mild steel wire in the mig to weld them up.  Did my 6060 after a calf went through between the seat and the steering wheel about 25 years ago and never have had trouble with it since, the shift lever I mean, not the steer...
dscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dscott Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 9:21pm
      I think welding with just the 7018 would be my choice. 6011 is a deep penatration rod and may give you trouble with burn threw. About the only times I use 6011 is if I'm welding something that doesn't or cann't be cleaned very well. Also I have found you can settle the arc of 6011 down some by dipping your rod in water for a few seconds.
