Is this for real?
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: Is this for real?
    Posted: 28 May 2012 at 8:10am
Over on e-bay someone listed a speed patrol that has a wd45 tractor in it. Did AC ever make them that late or is this something someone has put together? Item no. 200767327108.  Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 8:17am
http://www.ebay.com/itm/200767327108?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_sacat%3D0%26_nkw%3D200767327108%26_rdc%3D1
Don't believe it's factory with the power steering as a cylider in the front and hydraulics to raise it along with the original "wheel" lift.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 9:00am
Looks like the original hand wheels are nothing more than handles now.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 10:37pm
SN is WD73242 so it has a WD rear end at the very least, looks like a hybrid of about 3 tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 7:58am
Do you think someone took the WC stuff off, just had the front frame, then put on WD to it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 9:14am
Look close at the front end. It was cut off the original and welded back on to this frame. You can see a plate on each side added to stiffen it up.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2012 at 9:36am
Dave ,Now you know better ,if you see it you know it is . LOL.
