Oil Pan Help
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Topic: Oil Pan Help
    Posted: 23 May 2012 at 4:50pm
Ok, I have taken all the bolts out that were holding the oil pan and cleaned it with turpentine, but when I try to pull it off it won't even budge. I've got the two long bolts in the back off, and the lug in the front off, is there somthing I'm suppose to do or what? I need any advice I can get, and this is my 1950 B I'm talking about. I'm trying to replace the oil pan gasket because, it leaks like crazy. Thanks!
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 7:53pm
Probably just stuck, pry gently with a large screw driver and it should come off.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 8:45pm
A large wood chisel also works well to loosen up pans and covers. I use the ones that I can hit with my palm and work around the pan or cover. Its amazing how hard the gasket cement sets up (and oil can still leak thru) after 60 +/- years!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 9:01pm
Do not pry it, they are easy to bend.  I go around it using a rubber mallet, eventually it will let go from the gasket.
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 9:31pm
I'm still waiting for that money Daniel, do you have another story to tell me ??????
This page was generated in 0.016 seconds.
