Mounting tires????????????? |
TMiller/NC
Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |
Topic: Mounting tires?????????????Posted: 09 May 2012 at 4:45pm |
Is it easier (better) to mount 11.2 X 24 rear tires on the rim before putting the rim on tractor or after? Tim |
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1561 |
Posted: 09 May 2012 at 4:54pm |
put the rim on the tractor the install the tire. you wont be chasing the rim all over. also when done on the tractor you can use the weight of the tire to help you install it.
Gary in da UP
Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Posted: 09 May 2012 at 7:04pm |
Read this first !
TexasAllis
Posted: 10 May 2012 at 6:45am |
It's much easier to mount the tire on the rim if the rim is already on the tractor.
1944 Allis C
1960 Allis D-17 LP |
Bob-Maine
Joined: 11 Sep 2009 Location: Central Maine Points: 922 |
Posted: 10 May 2012 at 7:12am |
I wish I had read this about ten tires ago. But i have had great luck breaking beads by using a 12 ton hydraulic jack. With the tire/rim flat on the floor, put the base of the jack close to the rim edge, using the tractor drawbar to provide a vertical weight for the top of the jack to work against. It's good to hear that noise of the tire bead coming free from the rim. Saves a lot of hammering and swearing. Bob@allisdowmeast
nella(Pa)
Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3124 |
Posted: 10 May 2012 at 8:11am |
After cleaning and painting the rim I always coat the rim and tire bead with old rancid lard that was used for baking or deep frying doughnuts. I keep it in the shop for wood screws, tires or whatever. It makes mounting easier and prevents the tire from sticking to the fresh dried paint and if you don't paint the rim it makes tire removal easier the next time. You can't put too much on. I always change my 4020 rear tires on the tractor. Take a front end loader and break the bead with the bucket or the skid steer Bobcat. This is the easiest way I have found for the job. If you have liquid in the tire run a pump off of the pto to suck it out and pump it back in.
j.w.freck
Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
Posted: 10 May 2012 at 11:03pm |
that little tool in the video clip is pretty nifty.never saw one before.we have had tires repaired on our big tractors on the farms,right out in the field.very fast and back to work in no time...
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 11 May 2012 at 5:25am |
shucks....ya'll ain't lived....til you squirt starting fluid in them tires, them throw a match to make em seat!! whew!
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 11 May 2012 at 10:23am |
DALE, WHERE do you learn some of these things!?
SteveC(NS)
Joined: 12 Oct 2009 Location: Nova Scotia Points: 663 |
Posted: 11 May 2012 at 5:00pm |
Tim, I gotta say I had a chuckle when i thought to myself "is this guy the owner of miller tire?".
