Allis DISK
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: Allis DISK
    Posted: 28 Apr 2012 at 5:53pm
My son is disking with a 9 foot Allis disk, and is not happy, he says it is leaving mounds of soil following the outside disk blades, creating ruts the length of the field.  How should the disks be set??  the front ones now form a v pointing away from the drawbar and the back ones form a v pointing towards the drawbar.  Is there a better setting???
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
b170dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote b170dr Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 6:04pm
Is it a pre set wheel disc.  They will leave a small rut.  If the disc is set to deep on the back gang, level the disc out buy turing the crank in to drtop the front of the disc. I don't disc much anymore,since I use a finisher. I use  to pull a drag behind my disc to cover that little rut.  Roger
'64 B-10, '58 D-14, '60 D-15D, '58 D-17D, D-19, 170, 2-185D, 190, 68 D-21 11, 72-220, 7000,7030, F-2 G,w/5 Heads,L-2 G, 330 No-Till
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 7:46pm
Sounds like a disc to me.  Some are better than others but most all ridge at least some.  Count you blessin you don't a Deere disc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 7:54pm
Neighbor has a Deere, leaves a nice little hill to plant taters in as he discs out a field, the Massey 520 I bought & rebuilt has it's own issues but not to that extent.  I still have to pull a drag behind it or have the other neighbor bring down his finisher.
MI8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 8:24pm
Speed and depth are the biggest things i've found to make or not make a ridge.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 8:29pm
Does it have shaft extensions on the outside, with another blade bolted on, that is about 4" smaller in diameter than the main disk?  That is what our 2300 has on it, and it leave almost no ridge, to the point if you are double disking the field, you can't see where you have been at times.
Still in use:
D17 owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 9:38pm
We had a Allis disc years ago and loved it till she was just plain wore out pulled a drag behind it. Then we bought a JD that only made it one year because just what others said it made hills. Now we have a MF 52 that is all right but not like the allis. I think my sc disk dose the same job. But anyway a drag 2 feet bigger then the disk helps alot. I thought what Orange blood is say would be a good set up. Never had one like it but I think that would be the way to go.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 10:38pm
I pull this behind my AC disc to stop it. Don
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 12:27am
Like 8050 said..he might be going to fast...does it leave a mound in the middle too?
been there done that, not doing it again...
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 7:29am
Try shifting down a gear or throttling back some, my 45 plays with my 8' snap coupler disk. It doesn't ridge when disking stalks, it can barley cut todays corn stalks. LOL But it will ridge in worked ground and bean stubble.
AGCO My Allis Gleaner Company
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 7:38am
like orange blood said, the smaller disc on the end of the gangs will cure it. I don't know exactly how you would get this set up though, I'm not sure if Allis offered it as an option your model disc or not. Darrel
Charlie (NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 9:53am
decrease the angle of the V in the front gangs and adjust the tilt (forward to aft) so that the rear gang runs a little deeper.  I agree with others that a disc leaves a little furrow but I think you are saying his is excessive.
There is always going to be a little furrow on the outsides and a small ridge in the middle.
Most folks use a drag or some sort of smoother board on the rear to knock all of that down.  I agree about the smaller discs on the end too.
