d-15 front weights |
coastga ![]() Bronze Level ![]() Joined: 24 Jun 2010 Points: 21 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Apr 2012 at 11:38am |
I have a D-15 series II gas that I would like to install some front weights. What do I need to purchase to install the weights? I beleive I would need some type of bracket, and maybe a rod along with the weights.
Also, where is th best (least expensive) place to purchase these parts? I want to keep my tractor original.
Steve
There was just a listing of 4 slab weights in Iowa for $350 but they were gone right away. You can buy reproduction slab weights. The only other "correct" weights would be the doughnut weights for the front wheels.
repro weights: http://www.steinertractor.com/ACS180-front-weight This page also has the weight bracket needed and the rods needed. Gonna have a good chunk of change involved here for "original" look. Edited by CTuckerNWIL - 26 Apr 2012 at 11:53am |
What else do I need besides the weights?
The weight bracket kit and 2 anchor rods.
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5902 |
Probably lots of Cash to buy them when you find them !
Gary
Lester ![]() Orange Level ![]() Joined: 08 Jan 2010 Location: Indiana Points: 521 |
They also had inside halves wheel weights too.
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
we have the frt weight bracket can ship 1-574-342-4545 visa-master cards-
discover
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7513 |
What else do I need besides the weights?Deep pockets! Hard to find, VERY expensive when you do find them.
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Best to buy them with the tractor!
![]() Edited by Eldon (WA) - 26 Apr 2012 at 10:50pm |
ALLIS EXPRESS!
This year: |
houchens ![]() Orange Level ![]() ![]() Joined: 29 Mar 2012 Location: Sunfish, Ky Points: 668 |
I've got the front wheel weights on mine, they really help.
If you're needing alot of extra weight, try putting a tube in the front tires and filling them with fluid! That'll add alot of weight, probably more than my wheel weights would. Good luck.
8050 200 7010 185x2 D17-IV D15IIx2 D14 WD45 Deutz Allis 6260 Gleaner Kx2 Gleaner K2 Diesel 2300 discx2 600 and 333 planters 2 AC wagons several AC plows/chisels Rotobalerx2 Other Misc AC Equipment
1953CA ![]() Orange Level ![]() ![]() Joined: 01 Jan 2011 Location: Burlington, WA Points: 505 |
I agree with Eldon, alot cheaper route!!! |
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support" |
1953 CA, it looks like your air cleaner end cap is sitting on the distributor and governor.
Yup, I was cleaning the filter...
Not hard to find at all. Just go to the Stiener web page and order them.
Just in case I can find originals, What years and models are the weights interchangable with the D-15 series II?
The slab weights are all the same.
![]() The mounting is different from one tractor to another and the mounts are on the Stiener site. |
MBWisc ![]() Silver Level ![]() Joined: 13 Apr 2011 Points: 103 |
Looks good but it makes it kind of hard to check the power steering fluid.
