Torque tube oil WC
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Topic: Torque tube oil WC
    Posted: 25 Apr 2012 at 8:34am
I don't have my manual with me
Can anyone tell the correct oil for the torque tube, Is it the same as the transmission oil?  I'm assuming.
What is causing the thin paint like layer on the steel/cast iron.  the only thing that will get rid of it is carb cleaner.  It stands up pretty good against the wire brush even.
Edited by Redwood - 25 Apr 2012 at 8:34am
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 9:11am
Same gear oil as the rear and trans....
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 9:27am
thanks I thought so.. want to pick some up on the way home.
What I took out was heavier (again I'll assume, to wear)
