38 B magneto
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Topic: 38 B magneto
    Posted: 23 Apr 2012 at 4:34pm
I have a friend that has a 38 B and he thinks there is a problem with the mag.
No start and am assuming no spark. I know nothing about them.
What would be a good approach to checking it out?
I know it sounds kind of vague but that is all I have right now.
Any ideas?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 5:37pm
First have to find out for sure if there is spark or not. How good of friend, have him hold a plug wire while you crank it. Or you can just pull a plug wire off, stick a screw driver in the cap and hold it an 1/8" or so off of the plug and see if it jumps a spark when it comes around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 6:18am
We offer parts, service, and rebuilding. Drop us a line if interested....
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 7:28am
Mags are sort of a special breed, was a time lots of guys knew enough to get them to work. about all I can do is change points.  My sugestion is to first see if you have spark as Lonnie said -- if not send it to Steve to fix it- he is a good guy and you can trust him to do good work!!
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 10:00pm
If you don't have spark, clean the points. Drag a paper match stick through them a few times. They get a film on them from sitting. Bob
