6060 3pt lift |
Eddie ![]() Silver Level ![]() ![]() Joined: 25 Nov 2010 Location: North Alabama Points: 117 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Apr 2012 at 5:00pm |
Is there any way to slow the 6060 3pt hitch down when it's lifting. When running at working RPM's it lift's so fast and hard that it jerks the whole tractor. When running at idle it works smooth. Seems like there should be a way to turn the pressure down a little.
Edited by Eddie - 16 Apr 2012 at 5:06pm |
Allis Chalmers 6060
10' Howse Rotary Cutter 5' Tiller 5' Box Blade 4' Aerator Ferris Zero Turn Mower W/10' fold up sprayer John Deere 455 Lawn Tractor John Deere 955 w/loader & 60" belly mower |
AllisFreak MN ![]() Orange Level Access ![]() ![]() Joined: 07 Dec 2009 Location: Minnesota Points: 1586 |
I know what you mean, mine is the same way. |
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Yes there is an adjustment knob that controls the lift speed.
Charlie
http://www.agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/79005852
Lift Shaft Sensitivity Control (Item 236) Edited by Charlie175 - 16 Apr 2012 at 7:22pm |
Charlie
Charlie, can't get the link to work. May be my problem
Allis Chalmers 6060
It is located on the right side behind the lift control levers on the floor.
Charlie
I move that up and down and it doesn't change anything, I'm assuming you're talking the knob in the floor on the opposite side of the seat from the PTO gear knob.
Edited by Eddie - 17 Apr 2012 at 8:30am |
Allis Chalmers 6060
Yes that is supposed to control the sensitivity of the 3 PT. Maybe check the linkage?
Charlie
