Decal Help!!!
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Topic: Decal Help!!!
    Posted: 07 Apr 2012 at 9:46pm
Ok, when I look at a lot of the B's and C's on here they have large decals on the side of the battery box, however when I look at buying decals they only sell the battery box decal with the CA sets. So should I just buy a CA set to for the decal, or does that decal not even belong on the B's? All advice appreciated, Thanks!
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 10:17pm
http://www.oocities.org/wackerdecals/You can check with Lyle Wacker for a set of decals.  http://stores.djstractorparts.com (David Stockbridge MI) as well as some other vendors on this site.
Edited by irlbeck A-C'S - 07 Apr 2012 at 10:26pm
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 10:21pm
Since that decal would be the one detailing how to setup the pump for traction boost, and the B and C do not have the boost, it would be completely incorrect to place it there.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 7:34pm
  not used on the B-C TRACTORS   lost cause    1-574-342-4545
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 9:30pm
A lot of kits had a B or a C that people put on the radiator shroud too. The C never had a decal there and the B didn't till after the CA came out.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 11:47pm
Charlie is correct. We leave it in the kits though becaue customers expect it to be there.  Same with the air cleaner oil level decal.
JimD
This page was generated in 0.060 seconds.
