D17 Brake Springs |
DennyS ![]() Bronze Level ![]() Joined: 08 Feb 2012 Location: Savona,NY Points: 26 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Mar 2012 at 3:50pm |
I haven't been able to find a picture or a diagram of this. The brake spring ends ? Are they supposed to just stick out and hook over the edge of the hole in the housing ? Or are they supposed to hook over a small pin across the holes.
Rick ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3695 |
They just hook over the edge of the holes. Rick
Thanks, Now that mystery is solved...
Dave (NE) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2154 |
Be careful. I had the spring come loose after replacing the brakes on my D17 IV. Now I have to tear it all apart again to hook it over the edge of the hole again. I'll try to figure out a way to prevent that from happening a second time. Dave
Dave...You're talking about a Series IV and I believe that Denny is talking about an early series. Yours is a little more serious,since you have to pull the back axle housing back off. Normally,they just pop back in the hole on the early series D17. Rick
Yup, Rick, more serious.
donais ![]() Silver Level ![]() Joined: 29 Dec 2011 Location: Ramona Ca Points: 160 |
On mine (d17 s.3) I popped it through and put a nail a cross and popped it back in so it can't POP off and into the hole
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Dave I hope it was on the left side! I'm getting pretty good at mine, just finished up the left side of one rusted up 175...I think if all the bolts and pins came out easily, and I had all the seals, o-rings, brakes, anti-seize and thread sealant ready I could do that side in a couple of hours.
ALLIS EXPRESS!
This year: |
Eldon, could you stop by and help. I'd buy the beer!
How about the gas???? Just got in from working on the rh side of that damned 175...5 1/2 hours and I still have the hydraulic valve assy and wheel to put back on....(am putting on the assy from my 185 as the one on there the mounting plate is almost totally rusted away. |
ALLIS EXPRESS!
This year: |
Guess I'll just have to get Gatz to help again!
Gatz in NE ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1053 |
...you'll still need a supply of beer
The reason I askedd the question was that on my rear brake springs, One of them has a small pin through the spring loop. I think I might pin the rest of them. No popping back through then. Same idea as the nail. just a small round pin about an inch and a half long with a head on one end and a small cotter through the other end.
