D17 Brake Springs
DennyS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennyS Quote  Post ReplyReply Direct Link To This Post Topic: D17 Brake Springs
    Posted: 12 Mar 2012 at 3:50pm
     I haven't been able to find a picture or a diagram of this. The brake spring ends ? Are they supposed to just stick out and hook over the edge of the hole in the housing ? Or are they supposed to hook over a small pin across the holes.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 3:54pm
They just hook over the edge of the holes.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennyS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 11:09pm
      Thanks, Now that mystery is solved...
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 10:01am
Be careful.  I had the spring come loose after replacing the brakes on my D17 IV.  Now I have to tear it all apart again to hook it over the edge of the hole again.  I'll try to figure out a way to prevent that from happening a second time.  Dave
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 10:44am
Dave...You're talking about a Series IV and I believe that Denny is talking about an early series. Yours is a little more serious,since you have to pull the back axle housing back off. Normally,they just pop back in the hole on the early series D17.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 12:25pm
Yup, Rick, more serious.
donais View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 12:52pm
On mine (d17 s.3) I popped it through and put a nail a cross and popped it back in so it can't POP off and into the hole
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 3:50pm
Dave I hope it was on the left side! I'm getting pretty good at mine, just finished up the left side of one rusted up 175...I think if all the bolts and pins came out easily, and I had all the seals, o-rings, brakes, anti-seize and thread sealant ready I could do that side in a couple of hours.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 7:30pm
Eldon, could you stop by and help.  I'd buy the beer!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 9:38pm
How about the gas???? Just got  in from working on the rh side of that damned 175...5 1/2 hours and I still have the hydraulic valve assy and wheel to put back on....(am putting on the assy from my 185 as the one on there the mounting plate is almost totally rusted away.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 9:43pm
Guess I'll just have to get Gatz to help again!
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 10:59pm
...you'll still need a supply of beer
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennyS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 6:56pm
  The reason I askedd the question was that on my rear brake springs, One of them has a small pin through the spring loop. I think I might pin the rest of them. No popping back through then. Same idea as the nail. just a small round pin about an inch and a half long with a head on one end and a small cotter through the other end.
This page was generated in 0.035 seconds.
