wd45 gear oil?
wdforty5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdforty5 Quote  Post ReplyReply Direct Link To This Post Topic: wd45 gear oil?
    Posted: 17 Feb 2012 at 7:08pm
I checked the oil level at the square headed (3/4 inch or so) bolt under and behind the clutch lever. Oil level was about an inch or so from the top. Should it be at the very top, and I would assume 80w90 gear oil? Anyone ever run hy/tran in the rear end?
One more...how about capacity if I wanted to change it.
Thanks fellas!
smokey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 7:43pm
OK, You ready?
Rear end & Trans 17qts 80/90
Hyd 6 qts non-foam like AW-46
This is what my owners manual for the wd-wd45 said went to the local oil gas company and they converted it for me, there should be 3 drain plugs under the tractor to drain, just dont do what I did! Put the AW46 oil the trans, should have been hyd. I had a DUMM moment.
Good luck..
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdforty5 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 7:47pm
Originally posted by smokey smokey wrote:
OK, You ready?
Good luck..
 Thanks for the help, I can sure see how a fella could accidently fill the hyd. fill with gear oil or vice versa. I have an operators manual but it didnt say how full is full though. Did your owners manual mention the correct level? Im just wondering if I should fill till it comes out. I probably wont be changing for a while.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 8:02pm
NO, sorry but I just put in what it called for and it looked about right, I could see the oil in the bottom of the fill hole just below the plug, and the hyd. oil was right at the full mark on the dip stick, I drained all mine as I'am rebuilding a WD that had set for some time didn't want no water in there but I opened up the hole rear end to check bearings and seals also.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 9:30pm
Use hydraulic wet brake oil all the way.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 9:48pm
Originally posted by wdforty5 wdforty5 wrote:
Anyone ever run hy/tran in the rear end? Thanks fellas!
I have had Universal Hydraulic fluid in my WD45 since 1980. Works fine in the tranny, differential.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 11:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 11:26pm
Like Mack says.Hy tran in both.Fill 2 plugs rear of hyd fill(same levels) full up.
