170 -175 rear weights? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10835 |
Topic: 170 -175 rear weights?Posted: 14 Feb 2012 at 10:32am |
Any one have pics of a 170-175 with rear wheel weights mounted? I would like to see some. Thanks Tracy Martin
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 14 Feb 2012 at 12:07pm |
Bout the best I can do...still have to transfer all my file picks to the new laptop....
ALLIS EXPRESS!
This year: |
Tracy Martin TN
Posted: 14 Feb 2012 at 12:57pm |
Eldon, are those weights for early D17, or for D17 IV and 170-175? Are the early D17 weights differant? I was wondering because of the wheel center change. Thanks Tracy
Eldon (WA)
Posted: 14 Feb 2012 at 1:07pm |
These are the correct weights for the D17 SIV and up through the 170-185 series with 28" rims. You can spot them by the little round knob them.
ALLIS EXPRESS!
This year: |
Eldon (WA)
Posted: 14 Feb 2012 at 1:10pm |
xxx
Edited by Eldon (WA) - 14 Feb 2012 at 1:10pm |
ALLIS EXPRESS!
This year: |
Matt MN
Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Posted: 14 Feb 2012 at 1:13pm |
they should be correct for the series 3 and up to 185 with 28" wheels. yes there was another casting for the older style of wheel center also. |
Tracy Martin TN
Posted: 14 Feb 2012 at 2:26pm |
My parts manual shows the type I have. They won't fit my wheel without riding on lug bolt heads. They don't have the little round protrusion either. Thanks Tracy Martin
Lester
Posted: 14 Feb 2012 at 3:52pm |
Both stiles will work.
NC Bruce
Joined: 15 Sep 2009 Location: Mill Spring, NC Points: 224 |
Posted: 14 Feb 2012 at 9:19pm |
Tracy, here's what came on my AC 175 high crop. Don't drop on a toe when taking them off!
Eldon (WA)
Posted: 14 Feb 2012 at 9:26pm |
I also found out these segment weights fit on 38" wheels if they are reversed...but do inhibit lugbolt removal.
ALLIS EXPRESS!
This year: |
Eldon (WA)
Posted: 14 Feb 2012 at 9:28pm |
ALLIS EXPRESS!
This year: |
NC Bruce
Posted: 14 Feb 2012 at 9:31pm |
Eldon or Tracy? .....The rear weight that came with my AC175 (photo above)....is that an AC weight, or an aftermarket one?
Was it intended for AC175, or another model or make??
Eldon (WA)
Posted: 14 Feb 2012 at 9:35pm |
Bruce it looks like an aftermarket....if it is AC it will have AMxxxx cast into it.
ALLIS EXPRESS!
This year: |
NC Bruce
Posted: 14 Feb 2012 at 9:38pm |
Eldon; you posted before I could ask you...ha! Can you tell me more ?
I'll try to look at those weights tomorrow?
That's the tractor that just started leaking oil out the manifold elbow...dripping down onto rails. I'm afraid it's a ring or piston / engine problems?? Several AC fellows thought it might be injectors? only 3600 hrs?
MBwcIll
Joined: 03 Oct 2009 Location: Chapin Ill Points: 175 |
Posted: 14 Feb 2012 at 10:57pm |
The weights on 175 are AC weights, more popular on the 7000 series. I'll check the AM number tomorrow and post it. We kept them off our 7020 when we traded it. I now have them on our D15.
MBwcIll
Posted: 15 Feb 2012 at 9:57am |
I checked the number on our weights like the weights on "NC Bruce" 175. Andy reminded me they actually started out on our 1974 200.
The number is; 25887 -02-WA Perhaps the 300 pound D17 doughnut would appeal to your eye better. Either way both styles of D series pie sectional, the WD, the above weight or even F&H weights will all work for you. The 190/200 pie sectional weight would not work very well. |
Tracy Martin TN
Posted: 15 Feb 2012 at 11:02am |
Pics of them on a 170-175 tractor would be nice. Thanks Tracy Martin
dpower
Joined: 11 Sep 2009 Location: Madison Ne Points: 1579 |
Posted: 15 Feb 2012 at 11:20am |
Bruce that is a factory AC rear weight ive seen them on 180 and 185s to.
NC Bruce
Posted: 15 Feb 2012 at 9:52pm |
Looked at those weights on above AC175D tractor (photo), and the numbers are: 256687-02-WA Are these Allis Chalmers? or after-market?
Tracy, here's some photos up close. Is this what you asked for? Let me know if you want more? thanx,
Bruce Odel
NC Bruce
Posted: 15 Feb 2012 at 9:53pm |
NC Bruce
Posted: 15 Feb 2012 at 9:54pm |
Tracy Martin TN
Posted: 15 Feb 2012 at 9:56pm |
Bruce, they look like AC weights. Early casting had AM on them, I can't say on those. AC weights pictured in my book has 7 slots for bolts,4 grooves in register ring. How do you want to ship them. LOL Tracy Martin
MBwcIll
Posted: 16 Feb 2012 at 7:01pm |
I got to thinking, when I mentioned 300# D17 doughnut weights, there are two styles of them as well. Both are Rowe Martinsville, IL foundry and use four bolts to attach. One states D17 and has four small 1/2 round circles to allow room for the wheel rails. The other style just says Rowe FDR and it has five areas to allow room for rails and valve styme. The 190/220 doughnut weights will not work and have six bolts holes to attach.
Chris/CT
Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Posted: 16 Feb 2012 at 7:52pm |
I have the Rowe style 300 lbs on my 175, do you want a pic??
Tracy Martin TN
Posted: 16 Feb 2012 at 7:58pm |
Chris that would be great. Tracy |
Chris/CT
Posted: 16 Feb 2012 at 8:15pm |
Pic of weight;
