Chrome exhaust pipe
vyvyjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vyvyjim Quote  Post ReplyReply Direct Link To This Post Topic: Chrome exhaust pipe
    Posted: 01 Feb 2012 at 12:50pm
I see so many tractors with big chrome exhaust pipes and no muffler.  Is that mainly for show?  Will it add significant horsepower to my gas series IV D17?
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 3:11pm
Unless your current muffle has problems, it will not add HP. Only noise and bling.  We sell quite a few of them, but personally, I'm not fond of them.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 5:01pm
I personally only really like them on a diesel tractor.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 5:14pm
Strickly for looks just like on trucks. When you get my age,you will want your tractor to be quiet as possible. Around here there are alot of windshield farmers who have got to have their diesel pick-ups decked out with dual chrome stacks and black smoke boiling out of them. Most of these guys are the younger crowd,but occasionally an older guy with the same set-up--I figure it's the viagra kicking in.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 5:36pm
 Ear plugs and hearing aids in the next aisle over,  right, Jim?
Personally I like them on a puller,  But in black.
badjeep View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote badjeep Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 5:43pm
On my 200, the chrome stack I got was the same diameter as the stock muffler, I just cut the shell off of the stock muffler and slid it in the chrome stack. Sounds exactly like stock...
In the shed- 7020,7060, L2 X (2), CII, WD X (2), 200, 210, 611H, 440, Fiat Allis 345B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 5:47pm
My FD5 as well as my HD4 had chrome pipe , but had below hood muffler with a pipe um through hood , the chrome stack only extended it higher and made for looks.
 You can buy seconds from many truck places or on line of stacks with the bend you want on the end to either prevent water entry or direct flow.
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 6:08pm
Most of the time the dyno shows a slight decrease in HP with a straight stack. I like the looks of the black straight stacks better than chrome. On a working tractor I would run a muffler.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 6:48pm
We have chromes on both our 7020 and 7045.Both needed mufflers and the straight pipe was less than half price. Only bothers the neighbors. Keep the doors shut, A\C on, radio turned up..
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 6:54pm
I can show you dyno graphs with pickups where a straight pipe helped the horsepower...  In my opinion, if you like the sound of the engine, straight pipe it and live it up. But on a stock horsepower tractor theres not really much of a gain, except on the thickness of your wallet because a straight pipe is usually a ton cheaper.
Making a living farming with and working on Allis Equipment
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 7:07pm
well look at it like this a 1993 dodge ton cummins muffler got 22 mpg and straight pipe got 24-26 lol i think it helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 11:23pm
There was a write up a long time ago in Old Power Pride magazine and the dyno showed decrease in HP with a straight stack. I can't remember what tractor without digging it out.
A guy on youtube made a video of a B John Deere and it also showed decrease in power with straight stack. The length of the stack also affects HP.
If you have a vehicle that has a very restrictive system then yes maybe going to straight pipes does increase power. But I believe a good muffler(not to restrictive) is best. The engine should have back pressure.
I don't think there is a shop anywhere that will recommend running a straight pipe on a everyday driver. There is a reason why they make performance exhaust systems.
Edited by 79fordblake - 01 Feb 2012 at 11:25pm
John Sealey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Sealey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 9:21am
When a carburetor is jetted it is done with the exhaust and intake filter setup as it would be on the tractor car truck or whatever. If you change anything that affects the restriction in or out you will change the mixture. If you lower the restriction on the exhaust the engine will run lean. Less power on the dyno more mpg. So if more power is what your after you have to rejet the carb after making any changes. Which is just an adjustment on the carb if its like my D14.
Edited by John Sealey - 02 Feb 2012 at 4:01pm
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 11:57am
Okay. Post rethunk! LOL
Edited by Goose - 02 Feb 2012 at 12:07pm
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 12:05pm
Ya might want to re-think your post Goose.....
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 12:06pm
only turbo diesel for me.
This page was generated in 0.111 seconds.
