Allis G Engine Problems |
Prairierth ![]() Bronze Level ![]() ![]() Joined: 17 Jun 2011 Location: IL Points: 9 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Jan 2012 at 10:31pm |
Hello all. I have been getting some help working on my G this winter from a neighbor who farmed with Allis' many years back, not a G specifically though. Anyway, we have been having a lot of problems with it sounding like it was missing at an idle. He rebuilt the carb and installed a new float. All the plugs seem to be getting a spark, as we run the throttle higher it seems to get a little better but doesn't necessarily sound perfect yet. I know it is a shot in the dark and the description is pretty vague but any suggestions?
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Did you change spark plugs or wires? Check points. I would start there. No resistor plugs or wires. Carb doesn't usually cause a miss. You could check the manifold for leaks. spray it with brake cleaner when it is running to see if rhe engine speeds up. Bob
ibleedorange ![]() Bronze Level ![]() Joined: 08 Feb 2010 Location: Harvard, IL Points: 173 |
I have the same problem with one of my G's. Did not check the manifold, but will now.
Tractors; If it runs, use it. Motorcycles: Ride em like today is your last day.
Tony.Or ![]() Orange Level ![]() ![]() Joined: 18 Mar 2010 Location: Oregon Points: 1498 |
Check to see if dist shaft is sloppy, that will give ya fits. if points are bouncing around . Tony
Maybe out of time a bit?I would check for vacuum leaks and then look at the timing.
Edited by CTuckerNWIL - 29 Jan 2012 at 4:48pm |
Don(MI) ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: Michigan Points: 3895 |
If your electric is ok, are you sure your getting enough gas through to the carb?
Just took the tank off our G today, blew air back through cause she was a little plugged at the bottom of the tank where the shut off valve is. Much better now, also cleaned sediment bowl and carb.
Galatians 5:22-24
"I got a pig at home in a pen and corn to feed him on, All I need is a pretty little girl to feed him when I'm gone!" |
