chaarging system
pabob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pabob Quote  Post ReplyReply Direct Link To This Post Topic: chaarging system
    Posted: 20 Jan 2012 at 3:00am
off color tractor, but helping a neighbor.  JD 2030 wasn't starting and he replaced the battery.  Still not right and he called me.  The tractor wasn't charging and the idiot light was burned out.  Motorola alternator needed diodes and new brushes, this done by local alt repair shop.  We reinstalled alt, cleaned bat terms and topped off batt charge. Starts fine and charges.  Batt at rest 12.5 volts and 14.5 when running.  Rate of charge does vary with speed of engine. Here's the rub.  The idiot light is out at an idle but there is just a faint glow when full throttle. not really lit but just like an ember and you probably wouldn't notice in the sun light but in the dark shed you can see it.  This is a new one to me.  The shop said it might be the reg. but run it and wait to see if it works out. (right, my tractors don't usually heal themselves) Any ideas? thanks
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 6:04am
Most idiot lights have 12 volts applied to one side of the bulb and grounded thru the alternator. When the alternator is sitting still it grounds the bulb. When it is working it applies 12 volts to the wire that goes to the alternator and the bulb goes out becuase it has 12 volts to both sides. I would say that you have a bad connection on the key side of the light that is not carrying the higher amperage when the tractor is at high idle.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote pabob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 8:56am
thanks stray for the reply we'll give that a check and that sounds like it could be it
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 1:23pm
I've had car idiot lights that glowed a bit when charging. Maybe it would help to use a lamp that takes more current at 12 volts. There usually are several current (and light output) options for each lamp base and glass size.
Gerald J.
