Gas line
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Topic: Gas line
    Posted: 19 Jan 2012 at 1:56pm
Do you guys make your own metal gas line?
If so, do you get the line and fittings, then flare the ends? Where can a person purchase the materials?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 2:00pm
I use copper line and compression fittings from the hardware store. Makes it pretty easy and it looks good.
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 2:07pm
I do the same as Lonnie, but I like to use brass tubing.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 2:29pm
Someone said to use brake line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 3:08pm
Do you have the tools to do it with?  You need a bender also.  Brake line works real well and most of the time you can get the correct fittings on already.  Inquire at you favorite car parts store, e.g. Napa, Oreilly's, Motor Parts, etc.  Just take your existing ends with you.
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 3:24pm
NAPA has them behind the counter here, just get the right sized fittings which are already attached just bend to shape...
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 4:02pm
We offer fuel lines already made, but as the guys said, you can make your own. I use 1/4" brake line for most of the replacement lines.
Steve@B&B
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 4:47pm
1/4" brake line already has ends installea and you can bend it with your fingers.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 5:27pm
I go to NAPA and pick out one that has the right fittings and length from the brake line rack. Flaring tools and a cheapie bender are great additions to the tool box. As an alternative to using a bender you can clamp different sizes of pipe in a vice and bend the tubing around them.
This page was generated in 0.045 seconds.
