Buying Air Compressor - Help!
MBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Topic: Buying Air Compressor - Help!
    Posted: 16 Jan 2012 at 6:01pm
My 3.5 HP air compressor finally gave out today. I've been waiting for this moment so I can get a full- sized shop compressor to efficiently run air tools and a sand blaster. The best priced compressors I've found are at Harbor Freight but am somewhat hesitant to buy from them. I hate to save $300 and end up with junk!
Has anyone here had experience with Harbor Freight compressors?
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 7:32pm
I bought one from Lowes last spring! On sale for $379! 60 gallon vertical. No experience with the HF one though.
Greg Kroeker
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 7:35pm
i've never tried a harbor compressor but i did have a campbell hausfeld 5 horse 30 gallon maybe. direct drive. it worked ok but it was loud and was kind of slow. it wouldnt keep up when airing up tractor tires. so i upgraded to a 60 gallon from fleet farm. it was 400 if i remember right. runs pretty quiet and to top it off it was made right in minnesota. i havent tried a sand blaster on it yet but it runs my impact pretty well so far
Pete-IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete-IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 7:37pm
Bought a couple vertical 60-80 gal Ingersoll-Rand through Harbor Freight for work.  No problems.
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 8:04pm
I bought a Campbell-Hausefield from Lowes. Slow and didn't last very long. I had a PorterCable tankless from Lowes for 10 years and loved it. I need a small one for my work truck. Any recommendations there?
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 8:09pm
I have a Porter Cable 6 gallon portable in my truck.  Has wheels and a handle, so real handy-ONCE it is off the truck!
Greg Kroeker
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 8:45pm
About air compressors, tell me if I'm wrong, but the oil-less ones are loud & the oiled ones are quiet & thus more desired, correct?
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 9:12pm
In my opinion the best air compressor on the market is a rolair, hands down. Costs a lot more than anything you could buy at harbor freight or home depot, but your buying it for life.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 9:56pm
I've got a very old Quincy that's served me well. It's a single stage two cylinder and built like a tank.
Personally, I'd rather have a good used older compressor than some of the stuff found at the big box stores. My old compressor is a 3hp (motor data plate) but it's five times as big as a 7hp seen in stores. I don't understand how they rate the new compressors but something fishy is going on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:39pm
On the small 2 piston compressor heads I have I had broken valves which caused problems, they are just a flat spring steel valve that fatigued , easy to replace .
HP has nothing to do with the compressor , the CFM output is what you want to look at , and to get CFM you need HP .
 You could have what is called a 5 HP compressor and it only puts out 8 CFM at 45 PSI.
3 CFM at 110
 On the motors they are what they call special duty motors, compressor rated , 5/8" or 7/8" shaft to drive the belt. Most of these are not continuous run and are capacitor start/capacitor run.
 Oil-less units are diaphragm units with like a moving bellows . OSHA and state boiler codes call for annual inspections of ANY unit used in public space or business. There is a tank size limitation on this (why you see carpenters and roofers with units with small multiple tanks  or tanks under 6 gal exemption. (public space is anywhere public might venture into)
true 5 HP motor
Granger Compressors
Edited by Coke-in-MN - 16 Jan 2012 at 10:51pm
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:49pm
Hello MB   Not sure what type or model your looking at?   But here are a few thoughts to consider Amount af amps 220 volts is important to compressor location.    2 stage 175 psi.LARGE TANK,   vertical or horizontal,  This is a lifetime investment. Go on line for Harbor freight and Northern tool to compare,  is shipping FREE?
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 11:07pm
i bought a small Campbell Hausfeld direct drive from HF...had it a year so far, no problems, also have a 50-60 gal upright Black Hawk from Sams Club some 10 years ago, also a direct drive, no problems with that one also! i was in HF the other day, saw many name brands of air compressors in there, and had better lower prices than the same units elsewhere!
marion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marion Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 5:52am
I use a speed air from grainger in my shop, have had for 20 years is belt drive.  belt drive or screw is only way to go for shop compressor. if anybody needs a good one I have a 125 cfm ingorsol rand on wheels for $1500, under 300 hours, free jackhammer with purchase
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 6:01am
Do not expect to effectivley run a pressure pot sand blaster with anything less than 25cfm. Been there.......
My Homemade compressor for blasting....scheduled for some re-vamping this spring
<iframe width="420" height="315" src="http://www.youtube.com/embed/X5iN7A4KnMA" frameborder="0" allowfullscreen></iframe>
1968 D15D,1962 D19D
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 6:17am
The air compressor engineers have cheapened them up for the big box stores.
If you realy want an "industrial air compressor" you need to look at the CFM/Preasure ratings. Go with Coke's advise.
The universal answer to all questions is yes, how much do you want to spend?
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 6:32am
I just bought a small compressor from Northern tool but I checked out their larger compressors for future reference.  Very competative prices on name brands.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 6:51am
I bought a compressor from Orschelens probably around 20 years ago. In the last 10 years it has been used hard. It is a 7.5 horse with 80 gal. tank. I am not sure of the cfm's off hand but it has been a good unit. It has had two break downs since I have had it," check valves". I think the company that made it is in Minnesota," Classic Air" is the manufactor. The main thing for longevity is change the oil like it was your car, and keep tank drained daily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 9:48pm
I've thought in the past of building my own high CFM compressor out of an old engine. Take a old 4 cylinder (or whatever) engine and hook it up to a PTO shaft. Don't know how well it would work but it should provide some high CFM for sandblasting and such.
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 5:18pm
m16ty, if you're serious check out building a compressor out of a air cooled flat 4 Volkswagen engine on the net. There's a guy that sells a kit that converts 2 of the cylinders into the compressor. Ooodles of air. Thanks for jaring my memory I may revisit it myself.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 6:11pm
HP in electric motors The amount of power a motor can produce running continually.
Some how the manufactures saws and air compressors are allowed a different definition.
The amount of power a motor can put out just before it stalls.
Dusty
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 6:54pm
Also remember that you can plumb two compressors into the same line so if the price is right for buying two over one large one then you can go that route.  I've got a 32 gallon and a 12 gallon connected.   As I sand blast one kicks on and as I continue to blast away then the second one will kick on also.  Only if I blast for longer than 20 minutes will it start to run out of air.  I also installed one in the attic and If I did it over I'd put both up there to keep all the noise out of the shop.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 7:19pm
"MOST" of the $400. compressors will say about 5 HP and put out 12 CFM at 50 psi and 9 CFM at 90 psi. If your running a sand blaster or power tools for any length of time, you want about 16 CFM at 90 psi. 18-20 is real nice. You have to get up to about $800. minimum to get that kind of flow.  A more name brand like Quincy will cost twice that. I have an older Blackhawk with a big 2 cylinder VEE compressor that puts out 16 CFM and i works out great for me.  About 10 years ago i replaced a 7-9 CFM compressor that just could no keep up with blasting, Single stage is o.k., mine has a 125 psi setting and will run a blaster  for an hour straight and  hold over 90 psi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 7:29pm
this is about the smallest i would suggest buying
i dont know how fast this one runs, but i made it a point to look at several compressors when i bought, and all had 3400 RPM motors. I measured the pulley on the motor and pump and bought the one that had the biggest pump pulley so it rans slower than the rest. (about 900 RPM).. To get the same volumn as the others, i figured it had a bigger displacement of the pump.  Dont buy a small pump that is running 1400 RPM just to get the volumn out of it.
Edited by steve(ill) - 20 Jan 2012 at 7:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 9:33am
Thanks much for all the input!
I bought an Industrial Air from Farm & Fleet. 15.8 cfm @ 175 lbs and 17.5 @ 100 although I haven't seen more than 150 lbs yet. 5 hp, two-stage belt drive and 80 gallon tank. Same price as the Ingersol @ Harbor Freight but three year warrenty vursus two and higher output. Service is available on-sight. Actually, the local auto body supply store was very competitive as well. I plumbed it into my around the shop system with 300 gallon nurse tank. Should run air tools and my blast cabinet well. If I have to wait a bit for recovery (?) there is always something else to do during that time!  I plan to hire commercial service for large sand blasting.
This isn't someting I use everyday so am hoping it will serve me the rest of my life and potentially the next generation!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 10:00am
thats an excellent size, should work out great !
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 10:15am
I got one of the 5hp Ingersol Rand 2 stage compressors from Tractor Supply. They actually had them mispriced (I didn't tell them that but they lost about $600 because my cousin got the other one they had mispriced)
They are great compressors and they do great for painting and sanding on old AC's. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 8:35am
I failed to explain that the second year warrenty for the Ingersol cost an extra $100 for the purchase of oil and filter replacements so the actual warreny is one year. Also, the Ingersol was on sale and the Industrial Air wasn't. If ordered via internet the Ingersol offered free shipping. Farm & Fleet pickup was local as well as warrenty service at my shop. Hope it works out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 8:42am
Ever heard of schramm tractors? 6 cylinder ih engine, 3 power the tractor, 3 pump air. Local junkyard had one complete a few years ago. Kinda wish i had bought it.
Edited by powertech84 - 22 Jan 2012 at 8:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 11:44am
I did just what Stan talks about. I have 2 60 gallon compressors. They are "Rockworth Classic Air". Both have 3hp motors although one definitely has a continuous duty motor and the other has the special compressor motor. The continuous motor unit also has a small after cooler on the pump and a quieter air filter on it, otherwise they're the same. When the Cummins Tools travelling tool sale came through, $250 for one (it had a broken pressure switch) and $300 for the other (bought the next time they came to town) was just too cheap to not try. They're single stage, but I can run my blasting cabinet non stop and run my 10 gallon pressure pot style blaster out of sand without stopping. I do have them somewhat synced. I figured having them set so there is some time between each motor starting was probably a good idea from the surge standpoint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 11:49am
I haven't seen a tractor like that, but I have seen Schramm units as small as a V4 Wisconsin engine to as large as a 460 Ford that have half of the cylinders running and half of the cylinders pumping.
