wc block repair pic.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: wc block repair pic.
    Posted: 15 Jan 2012 at 12:25pm
I'd like opinions of this repair. The block was welded and I drove it around several times and it never leaked. I just couldn't stand the look of the weld so I made this flat spot with JB weld and when I was done I laid some 60 grit sandpaper down on it and tapped it with a hammer several times to try and get the cast look. What U think?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 12:44pm
looks good to me as it is a serviceable unit and looks like part of it will be out of site anyway ..
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 1:27pm
Looks good to me also. Stamp some sort of random number on it and non-Allis people may even think it's original.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 2:36pm
Looks like a part of the casting to me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 7:16pm
Start with X or EX. That'll get some attention:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 7:25pm
Looks good to me too.  Should've cut the heads off a couple of bolts and then glued them onto each side.  Would look like it is bolted in place.  REALLY P!ss someone off when they try to remove it!  LOL
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 7:51pm
^THIS^
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
