Identify Plow Update Numbers
AvillaMO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AvillaMO Quote  Post ReplyReply Direct Link To This Post Topic: Identify Plow Update Numbers
    Posted: 14 Jan 2012 at 4:42pm
I looked over the plow today and I found some numbers.  The moldboard number is 309215 and the frog number is 309241.  Is this for sure a #52 plow?
 My plow doesn't have the right share on it.  Would it be possible to purchase a new share or did Ben Franklin buy the last one?  I clicked on the link someone posted to research plows but the link was no good.
Thanks for all the help.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 5:15pm
   I think were confusing you. Your plow is not a model 52. A 52 is a snap coupler, 2 bottom, 50 series plow. Your plow is made from parts of a 50 series plow. The 50 series frame was only available with the snap coupler hitch from what I can tell from section 1 of the Moldboard plows parts catalog. Do you know if your bottom is a 12" or 14" ? Does your share have a number ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 5:40pm
   Your bottom is a #24 right hand with the welded draw rod bracket.
   Shares for 12" are numbers: 308860, 308863, 309270, 308866, 309235, and 309234.
   Shares for 14": 308861, 323654, 309270, 308864, 308879, 308880, 309235, 309234, and 308867.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AvillaMO Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 5:58pm
I think it's a 14".  The share number that is on it is 2512CR.  Looks like someone elongated the holes with a torch to make it fit.  It seems to fit good.  It's got some good rust pits in it so I'm not sure it will ever scour.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 6:54pm
Plow bottoms don't define frames, nor frames define plow bottoms. They were sold independently. Most plow bottoms fit most plow frames and plow bottoms are different for different soils and regions.
That frog number was used in #24 bottoms, 12, 14, and 16", as well as #124 bottom 12 and 14". The moldboard was used only on #24 bottoms 12 and 14".
Making new holes in the frog might be the most practical way to fit a share that has about the right length and the right point angle.
As RFDeere listed, AC offered several different plow shares for different ground conditions and made of different materials. They also often offered narrow cut, normal cut, and wide cut for some bottoms indicating how far past the right bottom edge of the moldboard that the shares extended. But they also made few shares that interchanged between many plow bottoms. But landsides and coulters fit most every bottom. And were offered in several styles and sizes.
Ben Franklin Johnson may have bought the last AC plow share, there were probably some at Scotch Grove Iowa but they were all sold at auction and so far the buyer's haven't spoken up on this forum.
Scouring may surprise you. I had some rusty plow moldboards and attacked them with a flexible flap wheel on a 5" grinder and it took off the rust but the original steel surface was so hard it only polished it. Couldn't cut it.
As I recall seeing your share, it looks good for a lot of wear yet.
Gerald J.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 8:13pm
I bought a new share 10 years ago for my 53 snap coupler plow, I think the dealer price was $124 at the time. So either Ben Frankin had a very long life or.....are you saying that I'm old?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AvillaMO Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 12:48pm
Thanks for all the help guys.  Some very good information.  I've googled the number for shares and haven't came up with anything yet.  I think I'll keep working mine over with a wire wheel and sandpaper to see if I can get it to scour.  I don't have any gravel type soil to pull it through to help clean it.  Mainly just gumbo-ee type dirt that sticks like glue.  I don't think your are as old as Ben Franklin...but you surely must be as wise to have found that share.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AvillaMO Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 1:14pm
I found a place that is supposed to have one of the shares listed for my plow.  The number he has is 309270.  The problem is he is saying this number is for a 12" bottom, not a 14" bottom.  Do you think he is mistaken?  Any good way to tell the difference?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 3:04pm
   As I listed above, share 309270 is listed for 12" and 14" bottoms. So it is for both, if I am deciphering the book right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AvillaMO Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 3:21pm
Okay, thanks.  So would there be any issues if I bought this share and used it with my current frog and moldboard?  What is meant by the term bottom?  How can 12 and 14 bottom parts be interchangeable?  Sorry, but I'm new to plowing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 3:40pm
   A bottom is what is below the main frame for making one furrow. The Frog, Moldboard, Shin, Share, and Landslide when assembled would be one bottom. A plow like yours that makes two furrows would be a two bottom, a plow that makes five furrows would be a five bottom for examples.
   As far as I can tell that share should work with your frog and moldboard. As long as the bolt holes and front (land) edge line up, it shouldn't matter how long the share is, it would just cut through the previous furrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 3:43pm
   Somebody correct me if I am wrong with anything above, Please. I aint no expert !
Post Options Post Options   Thanks (0) Thanks(0)   Quote AvillaMO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2012 at 12:04pm
Would you happen to know the part number and name for the hook or loop that goes on the plow bolt that holds the share on?  This plow bolt goes through the share, through the frog and then has some hook or loop thingy that is attached to a rod.  I think mine is homemade and I'm trying to figure out what it is and what it does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2012 at 12:32pm
   The part with the hook is called a draw rod and is part # 314585. The part that it hooks to on the share is called a share hook and is part # 308818. These parts and the bolt are what mount the share, I think that is what your asking ?
   I notice you keep posting these questions on YT to, there is no need to do that, this is the place for the best information on AC on the net !
Post Options Post Options   Thanks (0) Thanks(0)   Quote AvillaMO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2012 at 2:05pm
Indeed, this Forum is the place for great information.  I normally used the Massey YT board so please forgive me.
So if I'm understanding you correctly, the share that should be on my plow would be attached by one plow bolt and by one hook on the share?   Does the share hook "bolt" onto the share or is it made into the share itself? The share that is currently mounted on my plow has two plow bolts and no hook.  Maybe I need to look at it again and take some pictures.  I know this is not the correct share but one someone has modified to fit.  So if I do buy a new share I might have to find a share hook?  I suppose rod and hook parts are long since obsolete?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2012 at 3:21pm
Look at the hardware store for long shank hooks and eyebolts, some might be long enough or might be extended with a threaded rod coupling nut.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AvillaMO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 1:38pm
I took a picture of the plow share bolt.  It looks home made but I don't see why it won't work.
 My source for a new share fell through so it looks like I will have to make my old one work.  It's pitted so I'm wondering how it will scour.  I cleaned it as best I could.
Edited by AvillaMO - 27 Jan 2012 at 1:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 1:45pm
   The draw bolt is not factory, I can tell you that. Have you used this plow ? It looks like it is already shineing pretty good. What are you using to pull it ?
Edited by Rfdeere - 27 Jan 2012 at 1:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 1:46pm
   I would about bet this plow will work just fine the way it is, if adjusted right.
Edited by Rfdeere - 27 Jan 2012 at 1:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 1:48pm
Yes that hook bolt is home made. Look up your plow bottom in the plow bottoms book at http://www.grandpastractgor.com/phpBBS/index.php for a hint of a better picture. But what you have should hold the share OK. The pits will get sticky but will probably get polished and loose their stickiness eventually. I have an idea to help that, go to the farm store or implement dealer and by a spray can of Slipkoat or slipcoat, spray graphite paint and hit the whole share. It will wear down to the bare steel on the high spots and keep mud from sticking to the pits.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 1:56pm
   I don't know if Avilla has used this plow yet, if not plow with it first. Then see if there is a problem ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AvillaMO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 3:10pm
Here is the deal with the plow.  I bought it several years ago to plow my small garden.  I didn't realize at the time that plowing was a semi-technical affair.  I thought you just hooked it up and dropped it into the ground.  Needless to say I was disappointed with the results. This winter I've been trying to figure out how to be a better plowman.  I think my biggest problem was that I didn't realize that the plow had to scour.  With the help on this forum and the YT forum I've learned a lot and I'm truly grateful.  I don't have any relatives or neighbors to go to for any information so it's great that you guys volunteer your time to help a stranger like me.
Do you think the correct  share is just held on by one hook?
The share looks shiny because I spent an hour cleaning on it.  I'm pulling it with a Massey 165.
Steven
Edited by AvillaMO - 27 Jan 2012 at 3:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 3:37pm
   The AC share is held on like this one is, by the hook and that other bolt.   I looked up a MF 165, that would be a 52 Horsepower, 6000 pound tractor. How far can you get your right tire in (center of tractor to inside side of right tire) ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 4:29pm
With the graphite paint dirt shouldn't stick.
When I last plowed, I carried a 4" putty knife or a painter's doall tool to scrape any dirt sticking to the moldboard and it didn't take long to get the dirt scouring. That painter's doall tool is the 3" wide scraper with a sharp point and a cut one side designed for scraping paint off paint rollers. Its stiffer than the putty knife.
Yes the plow should be mounted the plow width, 12 or 14", from the inside of the right rear tractor tire.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AvillaMO Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 10:09am
One last thing on this topic.  I was just wondering how old this plow is?  I'm thinking maybe from the 1950's?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 1:16pm
   Looking at Swinford's book, 1950-1955 would be approximate for the Allis Chalmers parts. The three point hitch on yours is not AC, so who knows on it ?
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 4:47pm
Avilla, going from several decades of moldboard plowing that share will give you very little problem scouring. There is enough pressure and "solid" dirt going over the share that seldom does anything stick even with that pitting. The problem is after it is cut and slides over the moldboard, the dirt becomes "looser" and can start sticking to it. You can't have it too shiny in clay or gumbo, because even then it can and will stick. As has been said take some kind of flat blade to the field and scrape often until you get a polish. I take old hoes, heat the shanks and straighten them to make a tool to clean off the dirt. Works great and my plow tractors will have one tucked in between the frame rails and clutch. 30 0r 40 years of moldboard plowing teaches lottsa tricks just after you run out of cuss words!
This page was generated in 0.154 seconds.
