ED water pump leaks
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Topic: ED water pump leaks
    Posted: 10 Jan 2012 at 6:30pm
Have any of you had any luck with radiator stop-leak products stopping a leak in the water pump of a WD?  My hunch is that I might as well "bite the bullet" and put a new or rebuilt one on the tractor and be done with it.  Thanks.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2012 at 7:08pm
Open wide.... there ain't no fix for a leaky seal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2012 at 7:14pm
Agree with Steve. Do it right the first time instead of having to do it again later.
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2012 at 8:36pm
I've seen some brands of stop leak fix many leaks, but none will fix a leaky water pump seal. That leak is telling you that you need to fix the pump before you ruin the housing.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2012 at 6:31am
Don't even mess with the old pump. Purchase a new one, install it and don't look back. Everytime I talk to a customer on the phone  that rebuilt his water pump, he winds up replacing it a few months down the road cause' the thing is leaking once again. The only thing good about the job the second time around is the bolts come out easier. We carry new pumps, Tony C. carries new pumps as well as Jimmy D. Where ever or whom ever you purchase it from, you're way ahead of the game putting in new....Done deal!
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2012 at 7:25am
I've used the stop leak before but only as a very temp fix.  Usually just to get me to the weekend when I would have time to replace the pump or find the leak.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2012 at 11:45am
We have one, $111.00+shipping.
This page was generated in 0.093 seconds.
