wd-45 hyd pump removal |
Chris ![]() Bronze Level Access ![]() Joined: 12 Sep 2009 Location: Indiana Points: 155 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Jan 2012 at 5:49pm |
How big a job is it and what not to do taking it apart?Something must not be work'n right in mine.
Thanks, Chris
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
will come up between frame an mtg done many what is the problem????????????
may not need removal??? 1-800-254-3116
it won't raise anything, full of oil,linkage has not slipped
Down through bottom works better than up through the top. MACK
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Like norm said the pump will come up inside the frame rail. Did you try turning the "D" screw in and then back out first. That will sometimes relieve the pump and will start pumping again.
Don
Steve-Ohio ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: Ohio Points: 330 |
Norm--do you sell a general repair kit? Ours use to lift well a year ago, then gradully lifted very slowly, now it will not lift any weight at all.
tks Kirk (note--it does lift itself without a load)
yes i did turn the screw in and out on front of pump did not help, doing same thing as what steve posted
Not to hard to remove. when you take it apart do it some where clean that will contain the check balls. I use an old 1/2 sheet baking pan. its just springs, ball bearings and floating valves. no orings and only two gaskets. clean it out real well and check for broken springs. You'll need to get the springs from AGCO. the 5/16" piston spring costs as much as the rest combined. when you put it back on compress the piston plungers and stick a 8p mail in the slot to hold them down. if you tie saftey wire to the head its easy to remove them after the pump is repositioned where it belongs.
allischalmerguy ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Deep River, IA Points: 2893 |
Is the WD and the WD45 hydraulic pumps the same? Or are there some differences?
Thanks |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8623 |
The pump is the same but I think the 45 had something different about the design of the internal linkage in the rear housing. It effects the draft control.Don't quote me.
