Can anyone remember???
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Topic: Can anyone remember???
    Posted: 31 Dec 2011 at 1:34pm
What or where the topic was that showed pictures and discussed how to repair the oil filter base on the older model 226 engines.  For the life of me I cannot find it, no matter what I search for....  I seem to remember someone filling the void behind the base with JB weld or something similar, then milling it flat.  I wanted to find out what that was, JB weld gets pretty hard, and all I have is a flat file, but I want it to bond to the aluminum well.
Still in use:
Bruce(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 5:40pm
I use JB weld, fill it full. and file it down
To mill it flat, I use a big belt sander, in the wood shop
works good
Rog(NCWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog(NCWI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 9:31pm
I did the same thing but I added a 1/8 inch piece of steel to it when I put the last coat of JB weld in when to fill the void. This held the piece of steel on the oil filter bracket. Then I added a gasket between and tighten it up to the block. The steel, I think gave it more strength. I don't have a problem with it leaking.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 9:39pm
That would be me.
I filed the surface with a mill file to get a level surface, (most of them are warped) cleaned out the void and scratched up the pot metal in the void, made a 1/8" steel plate to match the surface, filled the void with JB weld and bolted it together (lightly) to cure. I then smoothed the edges and holes with small files, cut a new gasket, and it seals very well.
I have also used 1/16" aluminum rather than steel, and that worked pretty well also. You end up with a super gasket surface for not a lot of work or money, and you can't tell it's been modified.
Edited by GBACBFan - 31 Dec 2011 at 9:47pm
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 9:40pm
