1929 E 20 35 |
farmboycitygirl ![]() Bronze Level ![]() Joined: 16 Feb 2010 Location: 66528 Points: 128 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Dec 2011 at 4:00pm |
Anyone know where I can get a float needle for a 29 E?
split51 ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Guthrie, OK Points: 713 |
Try Norm Meinert
1929 20-35 sn17662
B1 w/snow blade B10 w/sickle mower B110 w/mower deck B110 w/tiller B112 w/grader blade B210 w/plo |
Darrell G (MN) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Green Isle MN Points: 1496 |
What Carb do you have?
Tricky Dickie ![]() Silver Level ![]() Joined: 05 Nov 2009 Location: North Yorkshire Points: 186 |
Should be a Kingston L
Have no idea on the carb - it is all brass except for the float bowl. Tractor used to set outside and got water in the bowl and froze. Once froze the float was ruined. Larry Swenson found me a float but somehow the needle was misplaced.
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3918 |
That's a Kingston L by your description. Norm Meinert, as stated above should be able to help you out.
Norm Meinert ![]() Silver Level ![]() Joined: 31 Oct 2010 Location: Davis illinois Points: 470 |
i have carb kits, new brass floats, new bowls, throttle and choke shaft, gaskets. can sell individual parts such as needle valve. will rebuild any ac carb. call 1-815-865-5372 or www.normsactractors.com
