First Allis - PICS
Turbo_760 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo_760 Quote  Post ReplyReply Direct Link To This Post Topic: First Allis - PICS
    Posted: 10 Dec 2011 at 6:32pm
Picked Up my CA today. I have not found the serial number yet. I think I read it is somewhere by the shifter.
Tractor runs very poorly but doesn't smoke. I think it will need some carb work and some ignition.
Tractor has been converted to 12V but the wiring is very messy.
Brakes do not work
Hydraulic Pump is unknown
Rims have some rust and are filled will calcium. Plan to demount and fix and paint
But overall this tractor should be a good project
I would like to get a 3pt hitch setup. Not sure if I should go for the snap coupler setup and get an adatper or just go for aftermarket
1951 CA
Cub Cadet 149
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2011 at 7:03pm
Turbo congrats ! Man ur gonna like it! I have one with the L306. I mow probably 100 hours with it every year. My oil on the dipstick you can still see through it as in clean. Unreal how great it runs. Nice find! Dana
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2011 at 9:06pm
Looks Like a Nice Tractor! Congrats!
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2011 at 10:44pm
Congrats, CA's are nice tractors. I have 2 and love them. Someday you will have a very nice tractor after you get it fine tuned.
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 6:46am
Congrats . Looks good.
David Gibson
http://www.darkecountysteam.com
1956 WD45
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 7:25am
Welcome to the last tractor brand you will ever want, and welcome to the forum.  Except for what you have already found as defective, the tractor looks pretty straight.  Nice find.
Still in use:
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 9:24am
Welcome! CAs are nice little tractors. I couldn't talk my neighbor into selling his, so I ended up buying a B. And then I found another B, and a plow, and a cultivator, and a Woods belly mower, and a sickle bar mower... you better get ready for more orange stuff to show up. The guys on here can give you good advice on just about anything.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 9:44am
Carbon plug wires are a pain and keep a vintage engine from running well. A choke wire that doesn't open and  close the choke all the way is another common pain. Then there's the plugged fuel line that keeps the engine running lean. That can be anywhere from the float needle, through the inlet adapter screen, to varnish in the line, in the sediment screen, or in the fuel outlet in the tank. And can be more than one of these. Start with these and a new set of plugs not Champion plugs and there's a good chance it will begin to run like a fine sewing machine. If not, then carburetor cleaning and valve setting are in order accompanied by compression testing.
Gerald J.
