Will an AC 200
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Will an AC 200
    Posted: 03 Dec 2011 at 10:47am
rear end [from torque tube on back] work on a 190XT III?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 1:11pm
Don't like the sound of that question.New 190 got problems?
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 5:54pm
Nah Steve I was just thinking out loud. I was talkin with someone who had said 200 rears were heavier than 190's, and for the folks with the earlier XT's that have tranny issues I wondered if it could solve their problems if a bad engine 200 could be bought cheaply and bolted onto an XT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 7:15pm
Yes, a 200 rearend could be made fit with very minimal changes. The transmission is essentially the same between a 190XT and a 200......nothing different enough to warrant swapping just to get a newer rearend.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 10:02am
biggest significance is the better brakes from a 200.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 10:03am
On 200's prior to sn 4001, they had the same band/disc brakes as the late 190XT III's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 11:46am
I dunno bout the brake thing , had them completely redone on a 200 once - the first year was good - then every time you,d use the dam thing one would hang or something would happen to it
