New WD-45 owner |
beezpic ![]() Bronze Level ![]() Joined: 07 Nov 2011 Location: Montana Points: 7 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Nov 2011 at 10:59pm |
I just purchased my first tractor, it's a 1956 (from the serial number) WD-45. My wife and I bought it to do things such as plow up our horse pastures, and move round bales. Problem one started when we unloaded it off the trailer, I had stopped at a gas station and filled it straight from the pump, which apparently broke 60 years of dirt off of the bottom of the tank, and clogged the fuel filter. I cleaned the filter 8 times, then cleaned the tank out, and all the fuel lines, and rebuilt the carb. Problem 2 came when it would run fine for a minute or two, then die. A friend of mine helped me with problem 2, by showing me that either the charging switch, or kill switch were bad (you had to play with either of them to shut it off or make it run, but it ran fine if the ground wire was disconnected from the magneto.) I decided to rewire it, but, whoever did the 12 volt conversion left the factory ammeter on the dash, and I wanted a voltmeter.
From what the previous owner told me, there was a kill switch to shut it off, and a key switch to allow the alternator to charge the battery. All was fine at his house, but I think a 50 mile 70 mph trip on a trailer changed some of that.
I have no experience whatsoever with a magneto powered tractor or vehicle of any sort. What I do know, is the alternator has one post on the back of it, then a plug in the side of it with two wires in it, so I imagine it's the "3 wire" alternator everyone talks about here. I'd like to use just 2 simple on-off toggle switches, and the voltmeter, so what wire from the alternator goes where?
I also wired off road lights to the front and rear (65 watt each, one each direction.) Do I want to keep the alternator turned off when I'm just running the tractor, since it's a magneto, and keep it on when running the lights, or does the voltage regulator handle overcharging the battery?
Sorry if these are stupid questions, like I said, this is the first thing over a lawn tractor I've owned, and so far it's plowed about 6 acres in the few weeks we've had it, so it will be used. I just have a lot to learn about repair and upkeep on something other than a good old car.
All help will be greatly appreciated, all my friends here in Montana are John Deere people, and aren't very willing or able to offer help, and I think they're offended by my choice (I always pick power over popularity,) and I look forward to using and restoring this old WD-45.
Thanks in advance,
Tim
Hi again,
After reading through other posts here stating that WD-45's never had a magneto, I looked through my owner's manual and it appears the green people were wrong and it does have a distributor. My bad. I have the owner's manual that came with it, and the picture matches what's on it, so I guess it's a distributor, just not like any car I've ever seen. I guess I'm really confused now. I thought a 55 year old tractor would be simple, but, it probably would be easier if it was green. Don't worry, I'm not going that way, I'll eventually figure it out
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9605 |
45's didn't come with a mag but that doesn't mean someone didn't put one on it. I find that the dist does look similar to one on a car. With a dist the wires should come out the top and have a round cap. with a mag they will come out the end (horizontal) and have a squarish cap. The dist will have an external round coil and the mag should have the coil inside . If it infact does have an alternator and 12v batterie make sure you have a 12v coil or voltage reducer if it has a distributer. Good luck with it and you'll get any help you need right here. HTH
Thad
deereequipment1 ![]() Orange Level ![]() ![]() Joined: 31 Mar 2011 Location: Southern MD Points: 261 |
you should get in touch with Steve at B&B and switch it over the electronic ignition.
He'll supply the wiring diagram and all needed parts.
Very reliable system! Welcome to the club, WD45's are great tractors. |
Raised on a CA,WD,D10 & D15.
Now, proudly own and pull a WD45 high crop, WD45, WC, also own a D-10, D-12, G and a CA. |
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18923 |
Welcome!! I agree with Deere, Steve will be the best shot for you. He will see your post and get in touch with you. You will get a lot of help here as there is a wealth of knowledge here on this forum. Congrats on your purchase of what I consider the best of Allis.
Dave in il ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
Welcome to the site. You have a very reliable and simple tractor and the best thing is you have a manual for it which is a very good place to start to get to know it.The "non factory" wiring will be a head ache until you've rewired it or at least sorted what goes were. I don't know if the 3 wire altenator has an internal regulator, if it doesn't I'd suggest replacing it with a new one wire Delco and rewire with a new switch and guage. Then you know what is what and the condition of everything.
Don't let those two cylinder Deere guys get you down, if they spend too much time around your AC then they have to admit to themselves they own an inferior tractor. LOL
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5058 |
Speaking of J.D. I helped a neighbor get a 1951 J.D. started. I thought it had a mag. It looks like a mag, and it has Wico on it, and no round coil near it. Surprise it is a 6 volt battery ignition with the coil inside it. It has a wire going to it. I thought it went to a kill switch, but the wire is the 6 volt power to it.
Dusty
TREVMAN ![]() Orange Level ![]() Joined: 04 Jan 2010 Location: Regina,Sask,Can Points: 1635 |
Welcome, and you have picked an excellent tractor both to learn on and to use. They are simple and reliable, buy a manual set off someone. You get owners, parts, and service manual, very useful. Trev.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
First, welcome to the site and you have a great tool for around the farm chores. Please help us help you by posting the tractor number and the engine number, or take pictures at least of the right side of the engine and post them. Many people misread the serial number lists and there are lists on the web that are way wrong. It sounds like your engine must have a magneto which tells me you do not have a WD45 engine. If you disconnect the wire to make it run, you are disconnecting the ground, kill switch wire from a magneto. The alternator and magneto have no connection to each other. Any working alternator will regulate itself whether the lights are on or off. If properly wired you should only need one switch to turn the tractor on and off and one switch to run the lights. There is lots of help out here for any questions you have and the only stupid question, is one you don't ask. Charlie |
There were some early alternators that did not have internal regulators.
Dusty
m16ty ![]() Orange Level ![]() Joined: 28 Jan 2011 Location: TN Points: 1474 |
Sounds like somebody has done a little "shade tree" wiring on your tractor. You are correct that the 45 never had a mag but who knows what somebody may have installed on it. A WD mag will bolt right up to the 45 engine. You could even have a WD engine in it (does it have a plate bolted to the side of the block?). The two separate switches to make it run is screwed up also.
Sometimes it's just best to rip out all the hacked up wiring and start over from scratch. There's not a whole lot of electrical on a 45. It's about as simple as they come to rewire. |
j.w.freck ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
m16ty...you are right as rain.1.get a 1 wire alternator 2 get a sharp pair if wire cutters and get rid of the current rats nest 3 get you 4-5 colors of various sizes of wire 4.draw up a wiring diagram and get started.quite simple once you get started.i have gotten into several of these supposibly rewire modifications on tractors and airplanes...surprising some of the rube goldburg messes you get into...be sure to observ correct polarity...
Okay, I did a little closer checking today, and the engine on this tractor doesn't match the factory owner's manual for the tractor. The intake and exhaust manifold don't match what the picture's in the owners manual are, and the "magneto" doesn't match the picture of the "distributor" in the owner's manual. My wires for my plugs come straight out of the back of what I think is the mag, whereas the owners manual shows the distributor at a 90 degree angle of what I think is the mag. The guy I bought it off of owned it for 6 months and said he had too many near death experiences on it with the narrow front end, thinking he'd roll it...he lived on basically the side of a mountain, and there were no places on his property that were'nt at least a 15% grade, so I can believe him there. The guy he bought it from claimed to have owned it from brand new and never really did anything to it. The guy I bought it from was the one who put the alternator on it, he said it was still 6 volt when he bought it.
Another mystery, looking at the factory owner's manual, is that it shows a charging switch, and a magneto switch, even though elsewhere it does mention a distributor.
As far as serial numbers, the number on the left rear of the tractor is 104290, and the number on the engine is WU214144GA.
I've added pics to this post, not sure if they'll come through, but if they don't, I'll try again tomorrow.
Thanks everyone for your responses, hopefully I figure this all out, but I can say that even with everything how it is, that tractor has already paid for itself in the work we've gotten done with it in the past few weeks.
Tim
Is the gear shift lever straight or is it curved? If it's straight it is a WD. If it's curved it still could be a late model WD or a WD45. The WD engine has a big metal plate bolted to the side of the block. A wd45 engine will have no plate.
I'm betting you actually have a WD but I could be wrong. Edit- according to the serial number you gave, the tractor is a 1951 WD. Edited by m16ty - 09 Nov 2011 at 10:59pm |
I can't figure out how to post pics here yet, so for now, the pics can be seen at: http://s909.photobucket.com/albums/ac299/timzrabbit/Allis%20Chalmers/
I hope this helps you all figure out what I've gotten into.
Thanks,
Tim
The shifter is straight, so, it's most likely a WD? What does that mean to me, what are the differences between the two? Did I really lose out in the deal? I probably didn't since I can do what I need to do with this tractor, but I'm interested to know the differences. Oh, and it does have that quick coupler thing, and has the spinout rear wheels, if that means anything.
Thanks,
Tim
79fordblake ![]() Orange Level ![]() Joined: 01 Jul 2010 Location: West Kentucky Points: 829 |
Looks like a WD......does have a WD45 carb though.....looks like a marvel schebler carb found on a WD45 anyway....can't tell if my eyes are playing tricks on me....The air hose is the same diameter on both ends it looks like also...so if it has a WD45 carb it also has a WD45 air cleaner.
Edited by 79fordblake - 09 Nov 2011 at 11:26pm |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8525 |
Definetly a WD. Straight stick,lifter cover plate & WD style manifold.Nothing wrong with all that,it's just not a WD45.If you ever have to overhaul it,put a 45 crank & D17 pistons in it and put a 45 manifold and carb on it.You'll be pleased with the results.
I'd like to overhaul it next spring, if for nothing more than to give it a completely fresh coat of paint, so I'll probably take your advice. Would that more or less give it the power of the WD-45? And is there really that much of a difference? The most we'll do with it is some plowing with a three bottom plow in solid rock, which it does fine now, and some snow plowing during the winter.
If you use D17 pistons as stated above it will have more compression than stock WD45 pistons...so you will have more HP than a stock WD45. |
Main diff is WD has strait cut gears and you shift gear teeth into gear teeth.45 has helical gears in constant mesh and you shift collars onto splines like modern day automotive trans only without a synchronizer.They just shift a little nicer but not a big deal.I have both.I could swear the ratios are a little different but can't confirm that. A WD is still a great tractor!
I could dig out the book but a WD was 35hp? and a 45 was 43hp from factory.You notice the diff when under heavy load. The extra 1/2in stroke gives it more "guts"!
If he changes to WD45 crank....D17 pistons...and maybe D17 governor spring he is gonna be going from 35hp to 50hp. |
It does have the marvel schebler carb, I just rebuilt it, so I know that for a fact, and the rebuild kit was for a wd-45. As far as updating it, since this is all new to me tonight, what would I be looking at for a crank? I was hoping to basically totally restore this tractor, besides using it, (I know, can't have the best of both worlds, but since it does what I want, I'd like it to look nice, and 60 year old paint isn't very nice looking.) Would I be better off finding a 45 to put my money into? And this one does have the snap coupler, and it's been updated with the top arm to a 3 pt. hitch on the back. You do have to turn a valve to switch between using the bucket on the front, and the 3 pt. on the back, but that's tolerable. Is it possible to add a second pump to make the front and back independant?
104290 is a 1951 WD. WU214144GA appears to be a 1949 engine, maybe a power unit transplanted to the tractor. The G on the end is for gas fuel and the A I believe means it had higher compression for high altitude.
There is no reason why you can't add a live hydraulic pump to run the loader. You might want to research cost and trouble verses using what you have. I added a valve to my 45 so I can run the lift arms separate of the loader. That's a great improvement over having a single line run everything at the same time. Here is a link to Bryan Smith's webpage with all kinds of AC info.
She looks pretty good to me for a working tractor.
It is possible that your WD has been upgraded already, most would have been overhauled at least once by now. I have a WD and a WD45 and the main difference is my WD would not pull a 3 bottom plow although it handles 2 very well.It could be our soil I suppose. my WD45 will pull 3 14's and the D17 3 16's or 4 14's.
Thats a wd, looks pretty good too. Dont hesitate to restore it. It may have 45 engine guts, if it runs well do a compression test, if that checks out, switch to distributor and Pertronix ignition, copper core wires, autolite 295 plugs, straight pipe the exhaust, 12 volt, all will give more power. Youve come to the right place for info, you should be proud of that little tractor. Trev.
DREAM ![]() Orange Level ![]() ![]() Joined: 06 Jan 2010 Location: Elberton,GA Points: 1828 |
Nice WD there.
You should get a lot of use out of it.
Posting pics is easy with a photobucket account. Just go to the album, roll the curser over the picture you want to post. A drop down box should come down below the pic. Go to IMG code. Left click on it. It will momentarily say copied. Go back over to the forum, hit quick reply or new post. Click on the text box, then right click and paste. Done.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Matt MN ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Here is a wiring Diagram that will work perfectly with the set-up you have. If you need new switches the part numbers by the items on the picture are valid part numbers you can find at any NAPA or Autoparts store. Let us know if you need any more help.
