|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| 180 PTO PROBLEMS |
| Post Reply   |
| DougG   Orange Level   Joined: 20 Sep 2009 Location: Mo Points: 8370 |  Post Options  Thanks(0)  Quote  Reply  Topic: 180 PTO PROBLEMS Posted: 14 Oct 2011 at 3:59pm |
   Just bought another  180 with pto problems - it engages and will turn - but you put it on a brushogg or a load and it will turn it but it seems as the pto is turning it gets to a certain point of rotation and wants to jump out of gear - if you try to hold it in- it really puts pressure on the linkage like somthing inside is out of round - maybe a bearing ? Anyone have an idea ?
| SHAMELESS   Orange Level     Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |  Post Options  Thanks(0)  Quote  Reply  Posted: 14 Oct 2011 at 4:33pm |
   my 180 does the same thing! pfft!
| Clay   Orange Level     Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10000 |  Post Options  Thanks(0)  Quote  Reply  Posted: 14 Oct 2011 at 4:52pm |
   If it were a hydraulic shift PTO, I would suspect an o-ring in the valve. | |
| DougG   Orange Level   Joined: 20 Sep 2009 Location: Mo Points: 8370 |  Post Options  Thanks(0)  Quote  Reply  Posted: 14 Oct 2011 at 5:46pm |
   Not hydraulic - its the manual linkage type
| Skyhighballoon(MO)   Orange Level     Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |  Post Options  Thanks(0)  Quote  Reply  Posted: 14 Oct 2011 at 8:44pm |
Doug - sounds just like what mine was doing.  Lever on shaft coming out of torque tube was bent and the rear PTO shaft had burrs not allowing engagement in the sliding coupler.  Remove the battery box to check the lever - bend back in place if needed.  Pull the rear PTO shaft to check for burrs and use a dremel to clean it up as needed.  See pics in link.  Mike http://s39.photobucket.com/albums/e176/Skyhighballoon/One%20Eighty%20PTO/ Edited by Skyhighballoon(MO) - 14 Oct 2011 at 8:44pm | |
     1981 Gleaner F2 Corn Plus w 13' flex 1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers | |
| MACK   Orange Level   Joined: 17 Nov 2009 Points: 7664 |  Post Options  Thanks(0)  Quote  Reply  Posted: 14 Oct 2011 at 9:08pm |
   The poor linkage on a 180 gets worn to where it don't shift all the way in then it starts jumping out. After it jumps out a few times it wears the pto shaft to where it will never stay in.
  Replace pto shaft and repair linkage or weld a strap of steel to it and bring it up between battery box and and torque tube like a D17 or 170 and you will take care of the problem.     MACK | |
| cadcorey   Silver Level     Joined: 21 Oct 2011 Location: pa Points: 69 |  Post Options  Thanks(0)  Quote  Reply  Posted: 11 Feb 2012 at 4:47pm |
   I see you have a 180. I am looking at buying a 170 but the pto has about 1/4" in and out thrust to it just by using your hand to pull and push on it. What i need to know is if there is and where the bearings are on the shaft and what it take to get it out and change them??? From what i can see on your pics that its all of taking the back plate off and pulling the shaft help. Any help you can give me on it would be a big help cause i am a big fan with Allis but i dont know much about these one.
| Skyhighballoon(MO)   Orange Level     Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |  Post Options  Thanks(0)  Quote  Reply  Posted: 11 Feb 2012 at 4:54pm |
cadcory - welcome to the forum.  On a 170 it's like a D17.  One long rear PTO shaft that goes from the rear of the tractor thru the transmission housing to the torque tube.  That's where the splined sliding coupler that slides on the front shaft engages to it via your lever.   The rear PTO shaft is held in by 3 bolts on the bearing carrier.  Drain both the transmission and torque tube housings before pulling it out the back.  I believe the bearing is pressed in the carrier?  Still fairly easy to get out and replace.  Also replace the rear seal while you are at it.  Also check the front spines for any burrs and us a dremel tool to clean them if  you have any.  Be careful reinstalling the PTO shaft as you have to push the shaft through a double seal between the transmission and torque tube housings.   Mike
 Edited by Skyhighballoon(MO) - 11 Feb 2012 at 4:55pm | |
| DougG   Orange Level   Joined: 20 Sep 2009 Location: Mo Points: 8370 |  Post Options  Thanks(0)  Quote  Reply  Posted: 11 Feb 2012 at 5:13pm |
   AH  i forgot of putting the -fix- for this tractor ; broke it apart and the ear was broke off of the coupler lever thing , when it got pressure on it , it would jump back , used coupler thing 60 bucks and like new ; i did redo the linkage too as it was worn
| HagerAC   Orange Level     Joined: 14 Sep 2010 Location: SE MN Points: 1195 |  Post Options  Thanks(0)  Quote  Reply  Posted: 12 Feb 2012 at 2:06am |
Mine did the same thing.  I just lengthened one of the linkages about 2 inches I think to accomidate for wear, and the bent lever on the shaft down below.  Works great now, did not have to replace the PTO shaft.
| cadcorey   Silver Level     Joined: 21 Oct 2011 Location: pa Points: 69 |  Post Options  Thanks(0)  Quote  Reply  Posted: 12 Feb 2012 at 6:52am |
   Mike,
   Thanks for the info. It sounds like it is not that big of a job to get it out and fixed. I have to drain all the oils and change them as soon as i get it here so that makes the perfect time to do it. You said about the double seals, are they lips seals that go back to back with one going forward and one going backwards?? Also one thing with it was the clutch. Is there any adjustment to it it?? When you go to put it in gear you have to wait a second or two to get it in while it grinds and shakes just a bit. Though when you release it to go you have to let it almost all the way up. Thanks for the help cause i dont know where else to go.   Corey | |
| Skyhighballoon(MO)   Orange Level     Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |  Post Options  Thanks(0)  Quote  Reply  Posted: 12 Feb 2012 at 10:40am |
   Corey, First - I assumed you had the single speed PTO on your 170 - my comments above and here below are based on that. There is no "clutch". The engagement is done by sliding that splined coupler on the front PTO shaft rearward so it engages and couples both shafts together. When the PTO is ground into engagement when either shaft is spinning, it grinds down the splines on the rear PTO shaft making engagement first difficult then eventually the burrs on the splines prevent the coupler from sliding on rear PTO shaft. Even a mangled one can be cleaned up with dremel tool grinding wheel or an air die grinder. You'd be amazed how much better it works once cleaned up even if the ends of the splines are rounded. The coupler is long enough that there is still enough length for good engagement. Once you've cleaned it the splines and reinstalled the shaft (after also replacing the rear bearing & seal), run the engagement lever thought several cycles while turning the rear PTO shaft in various positions to make sure you have good engagement. If it still seems sticky, pull it back out and clean up the splines a little more. Lots easier to find that out at this point point before filling both compartments back up with lube. If the rear PTO shaft is really mangled and can't be fixed, they are available new still. Open this link below in INTERNET EXPLORER and click on the page "DRIVE TRAIN - P.T.O. SHAFT & GEARS" to see a parts picture and list. You can click on other pages for the shifter/fork, etc. http://www.agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/79001560# I believe those double seals are like you say with one lip going on way and one going the other way. But you won't be changing those. You have to split the tractor to replace those. That's why you need to be careful reinstalling the rear shaft. HTH. Let us know if you have more questions. Mike | |
| cadcorey   Silver Level     Joined: 21 Oct 2011 Location: pa Points: 69 |  Post Options  Thanks(0)  Quote  Reply  Posted: 12 Feb 2012 at 12:43pm |
   Mike,
   All of that is very helpful, especially the page of the shaft drawing. After looking at it, i think the back snap ring might be broke and allowing it to move. As far as the clutch issue, i meant the main clutch to engage the transmission. Sorry i did not clear that the first time. With seeing all the info you have given me i think i will get this tractor since it looks like an easy fix even if i have to put new bearings in it and it runs very good. Corey | |
| cadcorey   Silver Level     Joined: 21 Oct 2011 Location: pa Points: 69 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Feb 2012 at 3:43pm |
   Mike,
  I got the trctor home today and pulled the pto out. It was the single speed shaft. The problem is the rear retainer ring is gone allowing it to move in and out. The problem now seems that i can not get that ring anywhere. I put a post on here hoping someone can help me. Thanks for the advice and the website. It has come in real handy.  Corey | |
| Skyhighballoon(MO)   Orange Level     Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Feb 2012 at 3:49pm |
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
