D17 throttle linkage |
| Author | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: D17 throttle linkagePosted: 28 Sep 2011 at 6:42am |
I'm looking to find the Governor Control Rod Rear (This hooks to the throttle control lever, bottom), and the Ball Clamp.
Mine is wore out. The rod I can probably fix but the ball clamp I can't
Charlie
| Sponsored Links | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Charlie175
Posted: 28 Sep 2011 at 6:43am |
Also what is the purpose of that big spring? Mine is broke but I guess it puts tension on the linkage?
Charlie
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 28 Sep 2011 at 7:22am |
Charlie - McMasterCarr has the ball clamp way cheaper than AGCO:
http://www.mcmaster.com/#ball-joints/=e9aboy Mike |
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
Charlie175
Posted: 28 Sep 2011 at 7:52am |
Maybe I didn't see the right one on that page but what I have a clamp that goes on to the rod with a ball on top to fit the other link rod so that it can rotate freely.
Charlie
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10139 |
Posted: 28 Sep 2011 at 9:44am |
Brian G. NY
This one looks similar to the one on my D-17.
I'm not sure what that big spring is for either.
Mine was also broken and I replaced it with a similar one
I happened to havr in "stock".
I guess the throttle works a little better with it than without it.
Brian G. NY
Posted: 28 Sep 2011 at 9:47am |
I meant to zero in on this one.
5 products match your selections ![]()
These 5 products match your selections
Ky.Allis
Joined: 31 Jan 2010 Location: Kentucky Points: 1036 |
Posted: 28 Sep 2011 at 1:25pm |
My parts book calls the spring a Compensating spring. I just put a new one on my D-17 and the only difference I see is that the throttle responds a little quicker. Without it you had to pull throttle down quite a bit before engine would speed up.
Charlie175
Posted: 29 Sep 2011 at 7:19am |
I ordered one of those ball clamps, thanks for the help. I will source a spring locally to see what it does.
Charlie
Charlie175
Posted: 29 Sep 2011 at 12:12pm |
Wow, placed order yesterday afternoon and it arrived today. Nice service!
Charlie
norm[ind]
Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
Posted: 29 Sep 2011 at 7:56pm |
we have the special throtle spring 1-800-254-3116
