G Electrical Problem |
oldironguy
Joined: 01 Oct 2010 Location: Shoreview, Minn Points: 373 |
Topic: G Electrical ProblemPosted: 24 Aug 2011 at 6:22pm |
One of my Gs has a well charged battery and a new starter switch yet the starter will not turn over. I think I have everything wired correctly. Any suggestions? I'm frustrated. Does anyone know how to convert a G from6 to 12 volt without butchering the sheet metal to fit in an alaternator? Does anybody make electronic ignition for the G at 6 volts or 12 volts?
Thanks.
Dick
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4793 |
Posted: 24 Aug 2011 at 6:42pm |
With 6 volt you need to have very good connections, I would check those first or leave the 6 volt hooked up for ignition and hook a 12 volt up to the starter to turn it over, they aren't nearly as picky about making good contact. at least you might find out if it's in the starter or the wiring?
Waukesha B, B, IB, G, styled WF, D17, 615 backhoe, 2-Oliver OC3's, 5 Ford Model T's, 3 Model A Fords, 34 Ford coupe, 57 T-Bird
Tedin NE-OH
Bad starter? Bad connections at battery.
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Posted: 24 Aug 2011 at 7:01pm |
Put a volt meter on the cable at the starter, see what it reads with the starter engaged.
Dusty
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4888 |
Posted: 24 Aug 2011 at 7:31pm |
Big cables(not wimpy car cables) and good grounds are the first things to check, also be sure the starter is getting a good ground to the block. If everything is right there is no reason to convert to 12 volts
Allis Express North Georgia
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12043 |
Posted: 25 Aug 2011 at 10:14am |
The 6V system is a very simple system, BUT it needs a little attention once in a while to keep it in tip top shape. Cables were mentioned, but make sure all grounds are clean and connections are also clean. Very important! If the system has its grounds and connections are clean, I would pull the starter and have it tested and inspected. Don't forget about the Battery either. Doesn't matter if its new or not. Do a draw test on the Battery FIRST! If the power supply passes a draw test, then move on. May save you a lot of time. We offer the Pertronix electronic ignitions in 6VPG, 12VPG, & 12VNG. We also offer a wiring system kit for a 12V conversion for the G if interested. Double check your Battery, connections, & grounds first before you do a conversion. Could be a simple overlooked problem....
Tony.Or
Posted: 25 Aug 2011 at 10:21am |
I will throw in my help also, if all of the above fail and you do change to 12 V. and your starter is dead. I have brand new 12 V. starters, bolt right on. $295 + $10.95 frt.
Thanks Tony
CTuckerNWIL
Posted: 25 Aug 2011 at 10:38am |
After owning a G for a short time, I see no reason whatsoever to change to 12 volts. That engine will spin over fine with 6 volts if you don't have other problems. If the tractor has sat for a while, pull the starter and jump it with your 6 volts. Check for mouse nests in the flywheel housing. If you have good clean connections to your battery and the starter switch is good, you probably have bad brushes or worn bearings in the starter.
oldironguy
Posted: 25 Aug 2011 at 7:29pm |
Thanks Guys.
I'll be back up at the farm next week and will follow up, especially on your suggestions. I'm encouraged by the consistency of your responses and by your encouragement.
Dick
