Bulk Fuel Tanks?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Bulk Fuel Tanks?
    Posted: 10 Aug 2011 at 11:21pm
Where is the best place to buy bulk fuel tanks? I only need 100 gallon tanks gasoline and diesel. Gravity,or hand pump would work best, but not essential. Any help appreciated. Thanks Tracy Martin
Edited by Tracy Martin TN - 10 Aug 2011 at 11:21pm
Wendell(OK/TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell(OK/TX) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2011 at 11:53pm
Friend of mine suggested I check with a big truck salvage for the tanks off the over-the-road tractors.  100-150 gallon.   Before scrap went up they were $150-$200.  I should have bought then.  Good luck
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 12:04am
that's a good idea wendell, them probably being aluminum and all, tracy you can also try john day company
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 12:06am
55 gallon barrel gets me by most of the time. Some times a 30 will do too. Personally I like the semi tank idea. I have never liked the flat bottom tanks.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 12:56am
Might want to check with your local fuel company. around here they won't deliver less than 500 gallons of diesel or 250 gallons or gas.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 7:33am
your local craigslist should have quite a few.  Take a flashlight to make sure how clean they look and how solid the bottoms are before you buy one.  There is always quite a few gravity and truckbed type transfer tanks on craigslist around here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 7:43am
If you plan on hauling it in your pickup, watch the capacity as over so many gallons it comes into transport tank and DOT rules come into play where you need placards, and CDL with has-mat and all sorts of rules ..
 Should have markings on any portable tank also to comply with rules . Now if you mount it then rules are different.
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 3:55pm
Tracy, I ran into the same problem as Dakota Dave.  Also if you don't use the gas fast enough, they stop deliveries.   At the price of gas, they should deliver it 5 gal.s at a time and gift wrapped.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 5:36pm
Tracy,
Get a fuel transfer tank for the back of a pickup and mount it securely it on a 2 wheel trailer. You can find these tanks cheap used, and for that matter they're not to bad new. You can go to town and pick up what you need yet avoid hassles of having a tank in the truck all the time.
Aside from most jobbers not wanting to deliver small amounts of gas it is cheaper to buy it at the gas station. I usually get 200 to 250 gallons of gas when I have diesel delivered and it's about 2 or 3 cents more than I'd pay at the pump in town. Quite a price to pay for convenience. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell(OK/TX) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2011 at 12:33am
Delivery???  Local feed and gas ON the highway has trouble getting gas because they don't buy enough at a time ( tank size) for them to stop as they go by.  Convenience store  just down from them has the same issue with frito-lay.  He has to meet the guy at the next stop to get supplies.  I was looking into these tanks because I'm tired of barrels rusting out and was gonna do the trailer thing.  Bought a D-15 LPG and I can fill that from the farm tank and they DO deliver.  Pretty much cut my gasoline down to 5 gallon jugs.  Better find a way to lock the trailer down and/or take the wheels off it to keep thieves from just taking the whole thing though.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2011 at 7:48am
Don't buy a used steel tank. They are ready to rust out then you have a problem. A new tank from tractor supply or any farm supply store cost less than the tank of fuel you loose when it springs a leak when you are not around.   MACK
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2011 at 7:57am
The way to keep thieves from steeling gas from bulk tanks is to paint "Wendells HONEY POT service, you plug 'em, we suck 'em"  on each side of the tank, then put a biohazard sticker near the fill point, and you won't have any problems.   You think I am joking but I am not, haven't lost a drop yet.
Still in use:
This page was generated in 0.191 seconds.
