D-17 hydraulic lift
kbrad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kbrad Quote  Post ReplyReply Direct Link To This Post Topic: D-17 hydraulic lift
    Posted: 01 Aug 2011 at 2:42pm
The lift on my D-17 will just start running lift on its own without mme even using it and nothing hooked to the tractor to be lifted . It only does this when the tractor comes under a load like pulling a drag disk etc. the lift arms come up own their own and when they are all the way up the pump just keeps pumping.The only way to stop it is to shut the tractor down and and restart and if you get it under a load it will do the same thing. Can some one help . Sorry for the long explaination.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2011 at 2:45pm
Sounds like the traction booster linkage is a little tight or the linkage rod is bent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2011 at 3:02pm
 It is supposed to do that if you are pulling a SC implement , but you should be able to shut it off by following the adjustments in the manual.
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2011 at 3:12pm
Put the traction booster lever all the way at the bottom of the quadrant. If it is and does it, something is bent or out of adjustment like John said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kbrad Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2011 at 6:46pm
Thanks guys , I will look at that .
This page was generated in 0.071 seconds.
