220 Hydraulics
Brad Cober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad Cober Quote  Post ReplyReply Direct Link To This Post Topic: 220 Hydraulics
    Posted: 18 Jun 2011 at 7:53pm
I m running a 1411 NH discbine on my 220 and its having trouble lifting it.  The tounge swings in and out with no trouble.  The header tilts up and down fine but I can hardly get it to lift the whole machine.   Is there any adjustment or is my pump only working half of what it should?
thanks for the help.  I need to post pics soon as well!
brad
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2011 at 8:28pm
Have you tried switching the remotes to see if the problem moves or stays the same?Remote prssures are adjustable at the valve. If they need adjusted, or the pump us weak, or if you simply have too small a cylinder can only be determaned with a gauge and a service manual. Good thing is the pumps are  rebuildable in the average farm shop and parts are available both aftermarket and through AGCO. Read carefully before you start adjusting as there are several differant hydraulic systems on the 220 and adjustment proceedure varies with each one. If youhave the double pump it is also available new aftermarket.
Edited by Butch(OH) - 18 Jun 2011 at 8:31pm
Jim NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2011 at 10:31am
We've got the same problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2011 at 12:24pm
First, you need to obtain a 3000 psi gauge and attach a Pioneer (or whatever ends you use) nipple to it. Plug it into any of the couplers on the back of the tractor and at half throttle or more, activate that outlet and make the hydraulics squeal.....you should have 2200 psi minimum and 2400 psi would be better.  If the lifting problem is only after the oil is good and hot, check it cold and recheck when oil is hot. Probably a bad relief valve, but until you plug in a gauge, it's all speculation.
Mike NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2011 at 8:36pm
Dr.Allis we put a guage on and the most we could get was 2200 psi at half throttle and wide open. Now where do we go?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2011 at 10:22pm
If I was there, I'd adjust the pressure to 2400 psi and see what happens. Relief valve is located on the left front corner of the hyd valve stack with an acorn nut pointing towards the front. Also make sure the unit you are having difficulty lifting (NH1411 discbine?) is greased/oiled well in the axle lifting saddles for minimal friction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2011 at 3:54am
I checked it after it was hot last nite was 2100 wide open
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2011 at 6:22am
Without a flow-rater GPM measuring tool we're guessing. I'd still try to adjust the relief valve  and see if it will even raise the pressure when hot. You may have a bad/leaking relief valve or a pump needing rebuilding.
This page was generated in 0.035 seconds.
