Wd rpm
Tripp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tripp Quote  Post ReplyReply Direct Link To This Post Topic: Wd rpm
    Posted: 20 Jun 2011 at 2:45pm
Is there anyway to increase the stock rpms over 1400?
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 2:52pm
D17 govenor spring will increase it. I have my WD45 running 2300.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tripp Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 3:14pm
Will  that many rmps be ok for a stock wd motor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 5:53pm
A stock WD and WD45 run 1700 to 1725 RPM wide open no load. ...1400 is rated (PTO) speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tripp Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 8:47pm
O.K. but how much is too much, in R.P.M.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 9:44pm
What do you intend to do with it??? Hell, you can run it at 3500 for a short time if you ain't scared.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tripp Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2011 at 7:41am
Farm stock puller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2011 at 8:03am
Many, if not most organized clubs allow only certain RPM's for a specific model of tractor....some say stock (1700 rpm).....some allow 10% over (1870 rpm)...others 20% etc....even others may allow 3000 rpm max.......If you install a D17 governor spring, it should net you 2000 rpm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tripp Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2011 at 8:14am
Tanks Doc , any idea where I can find one?
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2011 at 8:42am
WD and 45s had a heavy duty spring you buy at Allis that made the engine run over 1800 rpm, although I do not know if you cane still get them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2011 at 12:51pm
Call Sandy Lake. They should be able to run one down for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tripp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2011 at 6:17am
How do I get in touch with her?
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2011 at 7:21am
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tripp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2011 at 8:42am
OH! She's a company, I'm a tard.
This page was generated in 0.260 seconds.
