disks for my panter
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: disks for my panter
    Posted: 30 Apr 2011 at 10:36pm
Any one know of a good source for new disks for my #78 planter row units. Agco is a little high priced on em. They are 13 inches, and the bearing has a 5/8 hole for the mounting bolt. I would like to find them as a complete assembly (the bearing already riveted to the disk). Thanks, Darrel
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2011 at 11:53pm
does shoup have em? mine are gittin a little thin too, thinkin next year i might replace em.
frankmi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankmi Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 9:11am
www.shoupparts.com or try www.agrisupply.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 12:17pm
Thanks guys, Darrel
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 8:02pm
As stupid and backwoodsy as this sounds, we save the take-offs from our Great Plains No-Till drills.  When they get worn down to about 13" or so, they need replaced on the drill, and they bolt right up to the AC Planter.  If you have a friend or neighbor with a similar drill, you could get back in the field a lot cheaper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 8:09pm
Doesn't sound stupid or backwoodsy to me. Makes perfect sense.
Billoh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billoh Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 8:44pm
I went up to the neighbors and got some he took off of his Kinsey (spelling) planter.He took them off to soon,most of them are bigger then 13 in,bolt size is the same,looks like they will work.I haven't tried them yet.Maybe I will be able to find some 13 in or smaller.                       HTH     Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 8:46pm
maybe you can just re-adjust your planter depth and still use the bigger disks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 9:07pm
Or bolt them up in a lathe and turn em down to what you want. As long as you got some carbide tooling, it shouldn't take but a couple minutes a piece.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 10:03pm
On my 3pt planter that had #77 units on it, I put 13 1/2 in. great plains disks on it, and they worked by bending the little pointed guard on the front of them. I tried to take them off of it (cause it went through a fire, and I don't use it anymore) and put them onto my #78 units, but they are about 1/8 to 1/4 in too  big, and the pointed guard  can't be bent on the #78's. Too bad I didn't use it for one more season before it got in the fire, then they would have been worn enough  to work! Maybe C Tucker's idea of putting em in a lathe and turning them down would be an option, cause the discs and bearings are like new, and they didn't get hot enough in the fire to hurt anything. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 12:55am
i think my disks are worn down farther that that...will have to check
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 1:33pm
Shameless, Your mailbox is full. Darrel
This page was generated in 0.143 seconds.
