WC trans. ratios?
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: WC trans. ratios?
    Posted: 16 Apr 2011 at 11:04pm
Can anybody tell me what they are? Thanks, JM
Sorry about confusion, I was after the transmission ratios, thanks JM
Edited by JM - 17 Apr 2011 at 8:36am
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 7:25am
My book shows 7:1 and 5:1 plus different side gears for standard (WC104285 and up)and hi traction (prior to WC104285).
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 8:00am
I'm confused. The book shows 7:1 ratio with 7 teeth and 32 teeth which comes out to 4:57, 5:1 ratio with 5 teeth and 33 teeth which comes out to 6:60. The math doesn't work unless the ratios are including a change in ratio from different side gears?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 8:29am
The transmission gears/ratios are the same between a WC and straight stick WD because the transmissions are essentially the same, just located in a different spot on the chassis. Ring and pinion and final drive ratios would be different between WC's and WD's. If you notice, AC had this thing about 1st, 2nd and 3rd gears always being the same ground speed (2 1/2- 3 3/4- 5 mph) at rated eng speed and standard rear tire sizes. The WC was rated at 1300 rpms and the WD was at 1400 rpms yet each had the same ground speeds with different eng speed and rear tire sizes. The only real change came with the bent stick WD and WD45 which had 1st gear slowed to 2 1/3 mph and 4th gear faster that it's predecessor. D17's continued the trend even with the engine rated at 1650 rpm speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 8:52am
My mistake, I was looking at rearend gear ratios. Whoops.
