200 Axle Mount Duals
dnel45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Topic: 200 Axle Mount Duals
    Posted: 14 Apr 2011 at 3:00pm
I have worn out threads on my axle mount dual hubs.  The U-Bolt threads are wore also.  I called Unverferth and they cannot get these U-bolt style hubs anymore.  Any ideas on where to get decent used hubs?  Thought about retapping my hubs to bigger size, but that doesn't solve the U-Bolt problem and I'm sure those U-Bolts are hard to find.  Thanks.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 3:11pm
If you have the standard 9 bolt steel rim duals, you could find a pair of A-C factory "flower pot" cast adaptors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 3:13pm
Yeah they are the standard 9-bolt duals.  I believe 3 1/4 axle width
WI D-21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WI D-21 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 3:39pm
D-21 has the same size axle i found some massy hubs from a salvage yard i just had to get keys made because the keyway was a different size but that was only 30 dollars.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 4:20pm
Here is the A-C "flower Pot" cast dual adaptors for the 9 bolt rims on my D-21
WALLACE220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WALLACE220 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 8:06pm
Unverferth was able to get me new ubolts for my 220 hubs i would start there, if you have a good welding shop in the area they may also be able to make some.  As far as the threads in the hubs being wore out, i have seen guys use wheel weight bolts that you pound in (john deere 4020's etc)
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 8:32pm
Depending on the style of the hubs a 1066IH U-bolt will work. I bought a set from Unverferth about 3 years ago. If you cannot find them I have a buddy that wons a spring shop and can make them and ship them to you. (SWOH) Pm me if interested in going that route.
David (in Mi.) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David (in Mi.) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 9:00pm
  Try a local truck shop, they can usually custom make ubolts, at least at my truck shop they can bend bolts of all lenghts and diamater bolts to use as ubolts.
ranger42 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger42 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 9:18pm
I dealt with a guy out of Russiaville, Indiana for my 210 hubs. In fact, I traded him a pair of 200 9-bolt hubs for the 210 hubs. He runs Orem Truck & Salvage and one of his specialties is new and used duals, hubs, weights, etc. He has got a lot of stuff and is very knowledgeable.  The last number I had for the place was 765-249-3107 or 765-883-5626.  I would bet if he doesn't have it he would know where to get it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 9:56pm
ranger42, how long ago did you trade him hubs?? I bought a set of 9 bolt hubs for my 200 and 7060 from him a few years ago. Maybe the 200s were yours. He is a great guy to deal with. The number I have for him is 765-513-0610, I have talked to him within the last 6 months.
Jim in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim in MO Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 7:12am
       Try  Northside   618-282-2477 jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger42 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 6:07pm
Dan's 7080,  I traded him about 4-5 years ago...I had the Hubs sandblasted, but not painted - they had a little white paint left on them. However, I know Ray is pretty particular and he may have painted them. I know he taps the threads and makes sure they're clean. I was pretty impressed with him.
bhs3044 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhs3044 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 9:02pm
i got a set of 1086 international hubs that the u bolts should work i got a set of 200 hubs sitting right next to them i could try it on if you are interested. i do not want to get rid of my 200 one i am also looking for another couple sets i use them for tractor pulling i use them so i can mount pressed wheels on the tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 11:01am
Thanks everyone for all the info.  We found a local spring shop to bend the U's for us.  Those flower pot duals are pretty neat, I have never seen them before.  Thinking about helicoiling the holes in the hubs that don't tighten up anymore, theres about 5 total on both hubs.  Probably a temporary fix but we'll see.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 12:49pm
A heli-coil would actually be better threads than the cast by itself. If installed properly that is. I would heli-coil all of them if they are getting worn thin.
This page was generated in 0.336 seconds.
