175D fuel transfer pump
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: 175D fuel transfer pump
    Posted: 12 Apr 2011 at 11:12pm
Will a bad lift pump leak fuel into the crankcase? My oil seems pretty thin....
ALLIS EXPRESS!
This year:
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 11:18pm
Don't know how yers is built but any transfer pump bolted to the crankcase can develope a leak in the diaphram and put fuel in the oil.Ain't that a Perkins?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 11:25pm
Yes it is a Perkins...and the engine ran fine. In fact, I took it off and like a dummy pressed the lever while watching to see if there might be a leak and got a face full of diesel which shot out of the pressure port, DUH! Put one from my parts tractor on and changed the oil....I guess I will see how that one works. Is there a way to know for sure if they leak?
ALLIS EXPRESS!
This year:
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 7:35am
Yes Common with them. They can leak fuel into motor before they quit pumping! Put a new one on it and it will be good for long time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 7:41am
And to test you would need fuel supply hooked to it and pump it manually.
sandylakeimplement View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandylakeimplement Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 12:45pm
When ordering a new one you will need to know if it attaches with 3 bolts or 4.  Bill
Sandy Lake Implement
Sandy Lake, PA
724-376-2489
www.sandylakeimp.com
FIND US ON FACEBOOK
