my wd's |
firstac
Joined: 06 Apr 2011 Location: Van Wert, OH Points: 9 |
Topic: my wd'sPosted: 06 Apr 2011 at 6:59pm |
I have just inherited 2 wd's one of them is a 1951 on the other tractor I can't make out any of the serial # my question is? Is there any other way to date this tractor?
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4802 |
Posted: 06 Apr 2011 at 7:13pm |
Sometimes you can find a casting # on the rearend that would be a close date or you can go off the engine serial#.
firstac
Posted: 06 Apr 2011 at 7:38pm |
thank you for the info where would I find the engine serial # and then where do I locate info on engine #"s or casting #"S
wjohn
Posted: 06 Apr 2011 at 7:42pm |
The engine serial number should be sort of behind the carburetor. Welcome to a great forum!
David Gibson (OH)
Joined: 30 Oct 2010 Location: Hollansburg, OH Points: 493 |
Posted: 06 Apr 2011 at 8:00pm |
Welcome to the forum!
MNLonnie
Posted: 06 Apr 2011 at 8:04pm |
The engine # will be hand stamped and start with WD##### unless it's a newer WD45 engine, then it will start with 45-#####. Here is a site that has the info.
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25370 |
Posted: 06 Apr 2011 at 8:05pm |
the serial no on the hydraulic pump should match the tractor serial no.....if the pump is original. but, I suspect that if you spend a little time scraping paint you will be able to read the serial no on the tractor differential. Nothing but the differential no will be for sure, because during it's life motors, pumps, etc could of been changed
I am still confident of this;
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 06 Apr 2011 at 8:07pm |
Go here and look at the correlation between the year and engine serial #s:
http://people.clemson.edu/~wsmth/SNFind/esn_tsn5.htm |
CTuckerNWIL
Posted: 06 Apr 2011 at 8:08pm |
Some of the early WD's were stamped to the right side of the left brake cover also.
firstac
Posted: 06 Apr 2011 at 8:13pm |
would that be on top of the brake housing or on the back because I have removed the paint under the hole where I found the serial # on my 1951 and the casting is a little pitted but I dont see any numbers there. I tought I should be able to make out something but I see nothing
1951 WD, 1948 WD, 1937 unstyled WC (NW Ohio)
CTuckerNWIL
Posted: 06 Apr 2011 at 8:27pm |
On top, to the right of the cover.
CTuckerNWIL
Posted: 06 Apr 2011 at 8:34pm |
I found the serial # right of the left break cover # 3348.
So you have a fairly early WD from 1948. |
firstac
Posted: 06 Apr 2011 at 8:35pm |
Thanks everyone for your help I have located the Serial # on top of the break housing and it is a 1948. Thanks
DREAM
Joined: 06 Jan 2010 Location: Elberton,GA Points: 1828 |
Posted: 06 Apr 2011 at 8:51pm |
Welcome aboard! Great bunch here. Answers for any questions you may have.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Lonn
Posted: 06 Apr 2011 at 9:05pm |
Wink I am a Russian Bot |
firstac
Posted: 06 Apr 2011 at 9:09pm |
I hope to start restoring both of my wd's sometime in the near future so I may be posting my questions. I haven't pick up my '37 WC yet but I should have it in a few months. I also have aquired (3) lil genius two bottom plows which should be a lot of fun when I get them functional.
firstac
Posted: 06 Apr 2011 at 9:12pm |
lonn love the humor
