Pat's Easy Change System
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Topic: Pat's Easy Change System
    Posted: 31 Mar 2011 at 10:01am
Has anyone tried this hitch system?
Bill B
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 10:12am
You would still have to get off to hook up the 3rd arm.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 10:22am
JD has a simliar system but theirs works for all 3 pins. It's called IMatch and its been around for a quite a few years now.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 1:52pm
For $180 you can buy a standard 3 pt quick hitch that includes the top link.  Dad has them on every tractor he's got.
AaronSEIA
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 2:24pm
ok if you put them on that moves the equipment back aprox 3 or 4 inches on the arms but not the top link like seams that would change the geomatry of the three points up an equipment wouldnt stay level as it was raised and lowered also it would stretch the drive shaft that much as well we use a regular quick hitch and an extension on the tractor  with no problems just my thoughts
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 3:26pm
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 5:04pm
I own a Pats and have used it for yrs. The pros are it will accomodate any implement regarless of pin width or top link height. Cons are it will move ya back a couple inches. For most things thats not a problem and if your tractor has adjustable top link you can till make an implement travel on the level. I have a cat 2 set I will sell for 80.00. Half the cost of new.
abbaschild95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 8:48pm
i agree with aaron
Great-granfather's WC---- hopefully many more to come!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 8:52pm
They only work if all you stuff matches and you can't switch from cat2 to cat1. Almost none of my cat1 stuff is built the same so those one piece quick hitches are useless.
This page was generated in 0.077 seconds.
