D17 tractor rims
twinson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Topic: D17 tractor rims
    Posted: 25 Mar 2024 at 2:47pm
Is there a company that makes a quality spin out rim for the D17?  15/28 I believe is the size.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2024 at 3:48pm
Jim at OK Tractor found a rim for me.  Has been on the tractor for several years.  No issues what so ever.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2024 at 4:04pm
Tonys tractors has them at what appears to be s reasonable price
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2024 at 4:07pm
I believe Tony retired and closed up shop several years ago, even though the website still shows up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2024 at 5:17pm
Chances are pretty good your rims are not 15 inches wide, but 13 inches wide. Take some number 9 wire and make yourself a caliper to go on the inside of the spin out rails and measure your current wheels. A 13 inch will cost you less than a 15 inch and be easier to find.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2024 at 5:18pm
I've used this company in the past but it's several years ago, they're online also;
Wold Rim & Wheel
103 Ind'l Park Dr.
St. Ansgar, IA. 50472 . . . 1-800-443-9653
Oldwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 7:19am
Parts ASAP has them.  Here is a link for their 28X15 spin out-
Their price of $545 is quite a bit cheaper than many other sites.  I put 2 new ones on my D17IV this past fall, as both of mine were very much shot.
I have a question/observation.  I transferred my nearly new 16.9X28 tires over to these new 15" rims, and the rims almost appear too wide.  Not by a lot, but the body of the tire is almost a bit wider than the tread, so the sidewalls look more or less flat, rather than the normal rounded.  I always read that the rim should be 1" narrower than the tire section, so a 16.9 tire should go on a 15" rim.  Is that not so?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 7:25am
According to the official Firestone tractor tire chart, yes a 15 inch rim is what is recommended. BUT, A-C used the 13 inch rim for 14.9 x 28 tires (standard equipment) and when the tractor was ordered with the optional 16.9 x 28 they used the same width rim to keep their inventory simplier. If you ordered optional 18.4 x 28's you got a 15 or 16 inch rim from the factory.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 9:16am
Heywheel.com has them, 13's and 15's. Not cheap though, $470 for the 13's, $500 for the 15's. https://www.heywheel.com/page3.html I have a really nice pair of 13x28's in the shed waiting. Could have sold them multiple times already but holding onto them. Who knows, they may just go on the Series 3 NFE?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 12:35pm
JC garden supply, he comes to Hutch and other shows, helps save on shipping . Located in No Indiana
Edited by Pat the Plumber CIL - 26 Mar 2024 at 12:38pm
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 11:28am
We have the 13 and the 15 available.  We have sold them for 24 years now.
This page was generated in 0.176 seconds.
