Another WD bracket
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Topic: Another WD bracket
    Posted: 07 Feb 2024 at 3:25pm
I can't figure out where this bracket goes on the tractor. Anybody on here know.
   Thanks Tim
Edited by Tim NH - 08 Feb 2024 at 11:40am
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2024 at 3:59pm
It may be the clip that secures the fuel line and generator cable.
Don't know where it fastens; if it is that clip you might be able to find out by following the gas line and generator cable, looking for a handy 1/4" hole.
The one on my WD is long gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2024 at 6:14pm
Well that's where I'll start. Thanks Brian.
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2024 at 6:59pm
It holds the wiring harness to the fuel line between the carburetor and air cleaner.
The 15th Annual Exclusive AC Swap Meet will be held in Boonville, MO, March 6-7, 2026. See the club website for details: http://www.moacclub.com/
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2024 at 7:03pm
You mean the wiring harness isn't supposed to just drape over the petcock drain? LOL oops mine must be wrong
Just funny how few of these little items still exist after 70 years
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2024 at 7:11pm
I have a few tractors that have it still or otherwise i wouldn’t have known. Most are long gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2024 at 5:01am
Thank you Michael, I'll install it.  Tim
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2024 at 6:39am
I have several if you need more.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2024 at 7:37am
The model B's had a bracket like that under the drain cock dead center of the engine to hold the harness. Probably the same bracket used on all the models somewhere on board the Tractor...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2024 at 8:46am
I have a few more pieces I'm not sure where they go. The tractor at one point had a corn picker on it. Part #1 does not fit on engine drain cock. Part #1 is really the last part I feel, going back on.  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2024 at 7:02pm
Tim,
Part #1 looks like a bracket that would support linkage or a rod or somethin'. Can't help ya on the other two.  Sorry.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2024 at 6:41am
Number one looks like the wiring harness clamp with part of the clamp missing. I have found number two on the inside of the frame rail to hold a loader bolt. Three looks like  the carb linkage that has been bent. Four looks like a cozy cab bracket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2024 at 12:57pm
Would these be number one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2024 at 6:30pm
I'm not sure if that's it Mike, but it looks like it. I was informed by a PM, its for a the steel hydraulic line going to the back. I'll try my piece tomorrow. Lonn that bent rod must be tempered. I can't even think of straightening it. And each end is a different size. Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2024 at 7:24pm
Ok.
That part number in the wd45 book say’s wiring harness ( for battery box)
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2024 at 10:07pm
 Number 2 comes with the mounted cultivator. Maybe other attachments also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 6:56pm
Thank you Nathan for that info. Mike I'll be getting in touch with you.   Tim
This page was generated in 0.404 seconds.
